Simple to set-up, the Optoma WPS-3 wireless adapter lets you connect and display presentation materials wirelessly from a smartphone, tablet, laptop or netbook. Instantly download and install the powerful yet intuitive software to get connected, and then just click play to start projecting. Featuring advanced WEP 64/128-bit wireless security protection, the WPS-3 ensures your information is always safe.
The most intuitive way to present
Instantly present from your phone or tablet using the free App: WiFi-Doc. Available for both Android and iOS devices, WiFi-Doc gives you the freedom to move around the room, share ideas and connect with your audience like never before, to create a more collaborative experience for everyone. -
Project wirelessly from your tablet, smartphone, laptop or netbook
Intuitive presentation technology at your finger tips effortlessly puts the audience in the palm of your hand.
- Optoma WPS-3 - network adapter - VGA - 10/100 Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- VGA
- Ports
- 10/100 Ethernet
- 92.3 cm x 4 cm x 2.2 cm
- 52.2 g
- Cabling Type
- Ethernet 100Base-TX, Ethernet 10GBase-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 802.11b/g/n
- Frequency Band
- 2.4 GHz
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Network adapter
- Form Factor
- External
- VGA
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wireless, wired
- Cabling Type
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Remote Management Protocol
- HTTP
- Frequency Band
- 2.4 GHz
- WPS
- 1 x 100Base-TX - RJ-45
- Connections
- 1 x display / video - VGA - 15 pin HD D-Sub (HD-15)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- FCC
- Power Device
- Power adapter - external
- OS Required
- 92.3 cm
- 4 cm
- 2.2 cm
- 52.2 g
