NewStar Flatscreen Wall Mount 23-60" 1 screen Tilt Vesa 7
Quicklinx: C3Q5WS00 Mfr#: PLASMA-W240
The NewStar PLASMA-W240, allows you to mount a LED/LCD/Plasma TV to any wall. Cause of the flexible hole pattern of this system is this wall mount useable for almost every TV up to 52 inches. This wall mount allows users to tilt screens up to 20 degrees. This wall mount is easily to install by using the VESA hole pattern at the rear side of your TV. This wall mount can be used when the maximum distance between the holes (left to right) is 40 cm. The upper and lower holes allow a maximum distance of 40 cm. The PLASMA-W240 is made of aluminum and is mountable to any wall. Including security lock.
  • Versatile mounting options
    Designed for flexibility, the Neomounts PLASMA-W240 bracket supports flat panels ranging from 23" to 60", accommodating a wide array of display sizes for a perfect fit in any space.
  • Enhanced viewing experience
    With up to 25° of tilt adjustment, this bracket offers optimal viewing angles, reducing glare and enhancing the audience's viewing comfort, whether it's for home entertainment or public displays.
  • Robust design
    Capable of supporting flat panels weighing up to 50 kg, the PLASMA-W240 is built for durability and reliability, ensuring your display stays securely mounted.
  • Universal compatibility
    Featuring a flat panel mount interface that ranges from 75 x 75 mm to 400 x 400 mm, this bracket is compatible with a vast range of TV sizes and brands, making it a versatile choice for any installation.
Neomounts PLASMA-W240 bracket - tilt - for flat panel - black
Bracket (tilt) - wall-mountable
5.9 cm
Tilt
25°
Adjustments
Tilt
Recommended Use
Flat panel
Recommended Display Size
23"-60"
VESA Mounting Interface
Up to 400 x 400 mm, from 75 x 75 mm
Max Load Weight
50 kg
Package Content
Padlock
5-year warranty
5.9 cm
Package Content
Padlock
AV Furniture
Bracket
Design
Tilt
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
23"-60"
Tilt
25°
Adjustments
Tilt
Max Load Weight
50 kg
Limited warranty - 5 years
