Built-in ultra fast 4-port gigabit switch means even faster network performance! Surf, email, stream HD video, on-line game, make Internet phone calls simultaneously with the NETGEAR RangeMax Wireless-N Gigabit Router WNR3500. It features Automatic Quality of Service (QoS) that ensures reliable Internet, voice, video, and gaming applications.
- NETGEAR RangeMax WNR3500 - wireless router - Wi-Fi - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
- Frequency Band
- 2.4 GHz
- Remote Management Protocol
- HTTP
- Firewall protection, NAT support, SPI, DoS attack prevention, IDS, VPN passthrough, URL filtering, firmware upgradable, QoS, WPS
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
- 17.2 cm x 3.9 cm x 22.6 cm
- 0.56 kg
- Microsoft Certification
- Works with Windows Vista
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000 / ME / XP/ Vista
- Localisation
- English / United Kingdom
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- HTTP
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45
Aerial
- Aerial
- Internal
- Directivity
- Omni-directional
- Power Device
- External power adapter
- Included Accessories
- Vertical stand
- Cables Included
- 1 x network cable
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Localisation
- Software Included
- Drivers & Utilities
- OS Required
- 17.2 cm
- 3.9 cm
- 22.6 cm
- 0.56 kg
Resources
The following resources are available for the NetGear RangeMax Wireless-N Gigabit DSL Router
Customer reviews
Write a review for the NetGear RangeMax Wireless-N Gigabit DSL Router here!
N stands for Not Working
Reviewed by Robin. Review Posted 11/03/2009
It's easy to set up, but then you have to wonder why you bothered.
The range is good, can't fault it there, but the performance is terrible.
I used this to replace another Netgear router, a standard 802.11g model.
I wish I hadn't. Web pages loaded slower than ever, downloads never got above 50k a second and yet the connection to the router was always fine.
Plugging in the old one again just to be sure it wasn't just my internet connection, webpages once again loaded instantly and my downloads were back up to the 700k a second that I was used to.
Terrible router, a quick search on the internet shows that other people also experience the same thing.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
