NETGEAR Insight BRK500 4-port VPN BNDL Router
Quicklinx: DWDZWS00 Mfr#: BRK500-100UKS
£387.58 ex VAT
£465.09 inc VAT
Have you ever wanted to reach the resources that you have in your office such as a file server or a NAS (Network Attached Storage) while you were out on a business errand or a customer visit and found yourself stranded?
Has your business grown and you have a well-established network in your main office, and want your employees in your satellite offices to access the same resources?
NETGEAR has recognized the needs of modern businesses and summarized them in the NETGEAR® Insight™ Instant VPN Router. A business-class router with Instant VPN technology, world’s easiest and most user friendly way to remotely connect to your office as if you were there and never left. It has never been this easy to connect multiple offices together as if they were on one and the same network and shared all the same resources.
The VPN connections are encrypted to offer a secure link between your laptop and your office whether you’re on the road, at a coffee shop, or in another country. The same is true for site-to-site connections, when you decide to connect your home, office, or several other locations that need to be interconnected.
In addition to being a high performance router for small to medium-size businesses, it also offers a Stateful Packet Inspection (SPI) firewall supporting over a hundred rules to keep the bad guys out and your business safe.
Finally, with NETGEAR Insight, you have visibility and access to all features from routing to VPN setup, configuration, management and monitoring all from a single pane of glass, on your phone or laptop.
  • Easy and secure
    The NETGEAR Insight Instant VPN router provides both secure yet easy site-to-site tunnels and secure access for remote clients. Never before has connecting to your office been as easy as "tap and go". Once you connect and onboard your Instant VPN router using either the Insight app or the web portal, you are able to use the Insight mobile app or the laptop client to quickly, easily and securely connect to your office from anywhere in the world and continue working as if you were in the office with full access to all the resources and assets that you have in your office.
  • Resourceful
    NETGEAR Insight Instant VPN router works perfectly with ISP modems, including cable or DSL broadband connections. Gigabit LAN/WAN ports keep your data moving at top speed. With Network Address Translation (NAT) routing and classical routing, all the users in your office can access your broadband connection at the same time. VLAN support allows for guest networks and better network segmentation and IPv6 support will enable you to future proof your network.
  • Flexible
    You can start with one or two Instant VPN routers and as your business grows and your needs increase, you can add more devices to your VPN groups (up to 3 Instant VPN routers) to have a complete meshed network between 3 locations. A VPN group consisting of a single Instant VPN router can handle 10 remote users and each additional Instant VPN router can offer up to 10 additional remote users.
NETGEAR Insight BRK500 - router - desktop
Router - 4-port switch (integrated)
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Desktop
WAN Ports Qty
1
Performance
VPN throughput: 60 Mbps , LAN-to-WAN throughput: 924 Mbps
VLANs supported: 4094
Network / Transport Protocol
PPTP, L2TP, NTP, PPPoE, DHCP, DNS, DDNS
Routing Protocol
RIP-1, RIP-2, static IP routing
Remote Management Protocol
HTTP, NTP
NAT support, VPN support, ISP, auto-uplink (auto MDI/MDI-X), SPI, content filtering, IPv6 support, VPN passthrough, firmware upgradable, QoS, DHCP server, DNS proxy, DHCP proxy, port triggering, DHCP relay, ToS, DoS protection, DMZ support
IEEE 802.1Q, UPnP
31.4 cm x 18.75 cm x 4.365 cm
1.55 kg
Europe
5-year warranty
Packaged Quantity
Enclosure Type
Desktop
Wireless, wired
Performance
Routing Protocol
HTTP, NTP
Encryption Algorithm
DES, Triple DES, RSA, MD5, IKE, SHA-1, TLS 1.0, SSL 3.0, PKI, 128-bit AES, 192-bit AES, 256-bit AES
Authentication Method
X.509 certificates
IEEE 802.1Q, UPnP, VCCI, cUL, C-Tick Class B, RoHS, X.509 v3, HMAC, LVD, FCC Part 15 Class B
1.7 GHz
RAM
1 GB
Flash Memory
128 MB
WAN: 1 x 10Base-T/100Base-TX/1000Base-T , LAN: 4 x 10Base-T/100Base-TX/1000Base-T
External power adapter
1 x network cable
Europe
31.4 cm
18.75 cm
4.365 cm
1.55 kg
Limited warranty - replacement - 5 years - response time: next business day , Limited warranty - technical support - 90 days
45 °C
90% (non-condensing)
Type: Router
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Brand: NETGEAR
