NETGEAR Orbi Router and Satellite Extender Home Wifi Kit
Quicklinx: CBV0WS00 Mfr#: RBK50-100UKS
  • IEEE 802.11n
£344.14 ex VAT
£412.96 inc VAT
Meet Orbi – Fast, Secure, Whole Home WiFi
Orbi is the World’s First Tri-band WiFi System. From your front yard to your home office to your pool, Orbi gives you reliable, secure, and crazy fast WiFi to every inch of your home.
WiFi Everywhere
No more dead zones upstairs, no dropped connections through walls, just WiFi everywhere. The Orbi Home WiFi System reaches up to 4,000 square feet through WiFi barriers like walls, stairs and doors. Need more coverage? Just add an Orbi Satellite to instantly expand your WiFi reach.
Don’t Wait on Buffering
Buffering shouldn’t be a part of family movie night. Orbi helps prevent buffering and lag by creating a high speed Internet superhighway for all of your devices. The Orbi Tri-band WiFi System works with your current ISP’s modem to maximize the speed you are paying for.
Quick and Easy Setup
Unlike some WiFi systems, Orbi works with your Internet service provider right out of the box. You won’t need to change your current equipment to use the Orbi WiFi Home System. Orbi uses a single WiFi name (SSID) and with just a couple of clicks, your secure WiFi network will be ready in no time.
Routers. Not Just for Squares Anymore
Orbi’s sleek design and state-of-the-art technology steals the show. It gives your home a superior WiFi network that is both easy to setup and elegant to display.
  • Better Wi-Fi everywhere
    Take your Wi-Fi device from room to room and Orbi follows with fast Wi-Fi speeds.
  • Max Internet speeds
    Orbi uses Tri-band Wi-Fi to keep your Internet running at max speeds no matter how many devices connect.
  • Just plug in
    With simple setup from your mobile device, your secure Wi-Fi network is ready in just minutes.
NETGEAR Orbi WiFi System RBK50 - Wi-Fi system - Wi-Fi 5 - desktop
Wi-Fi system - mesh
Enclosure Type
Desktop
Wi-Fi System Components
Router, extender
Wi-Fi System Coverage
Up to 5,000 sq.ft
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz (1 band) / 5 GHz (2 bands) / 5 GHz (3 bands)
Intelligent Assistant
Alexa
MU-MIMO technology, beamforming technology, guest access, Circle Smart Parental Controls
16.3 cm x 7.87 cm x 20.3 cm
889 g
Wi-Fi system - mesh - 3-port switch (integrated)
Router, extender
Up to 5,000 sq.ft
Enclosure Type
Desktop
Wireless, wired
Frequency Band
Encryption Algorithm
WPA2-PSK
Wi-Fi Rating
AC3000
Mesh Networking
RAM
512 MB
Flash Memory
4 GB
Line Properties
Line Coding Format
256 QAM
Internet of Things (IoT)
Alexa
WAN: 1 x 1000Base-T - RJ-45 , LAN: 3 x 1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
Internal
External power adapter
1 x network cable - 2 m
16.3 cm
7.87 cm
20.3 cm
889 g
Type: Wi-Fi system
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11a
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11n
Standards: IEEE 802.11ac
Speed: 3Gbps
Brand: NETGEAR
