NETGEAR ProSafe Plus Switch 5-port Gigabit Ethernet
LIFETIME WARRANTY
Quicklinx: 6KGHWS00 Mfr#: GS105E-100UKS
Gigabit Power, 10/100 Simplicity
Today's growing businesses are both placing more demands on and relying more on their network. Companies are putting more applications and demands on their Ethernet Infrastructure. Using VoIP phones and IP cameras require more than simple plug-and-play connectivity. Additionally, Internet-based applications such as Hotmail and Google Calendaring have made keeping the network up a business-critical need. However, companies do not necessarily have more money or advanced training to deal with complex managed switches. NETGEAR's new ProSafe Plus Switches meet this growing need by providing easy to use visibility and limited configuration capabilities. To provide more insight into the network behavior, ProSafe Plus Switches offer traffic monitoring for users to observe traffic behavior. Additionally, if there are connectivity issues, these switches offer a cable diagnostic test capability that can identify and even locate problems in the cables. To optimize traffic through the switches, ProSafe Plus Switches offer both port and tag-based prioritization to keep latency-sensitive traffic moving ahead of less critical packets. Also, as a means of improving security or managing collision domains, ProSafe Smart Switches offer VLAN technology. ProSafe Plus Switches offering these monitoring and configuration capabilities at a slight cost premium over un anaged switches, delivering great value to the end user. GS105E product quick configuration
Additionally, furthering NETGEAR's support of the environment, ProSafe Plus Switches have power-saving Green Ethernet technology. The GS105E switch comes in a sturdy metal case with a fan-less design for silent operation.
GS105E product difference checklist
Use as a plug-and-play switch or use the configuration utility for simple setup
5 ports deliver up to 2000 Mbps bi-directional bandwidth on each port
Quality of Service (QoS) for prioritizing network traffic
Virtual LAN (VLAN) support for network segmentation and security
Troubleshoot connection problems via cable test
Port mirroring
Bandwidth management to avoid network congestions
Network traffic monitoring
Broadcast storm control
NETGEAR Green
Netgear Green Logo
Up to 60% lower power consumption
Auto power-down mode saves energy when port is not connected
Less transmit power when the cable is short (under 10m)
Packaging manufactured with at least 80% recycled materials
NETGEAR Plus GS105E 5-port Gigabit Ethernet Switch - switch - 5 ports
Switch - 5 ports
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
MAC Address Table Size
4K entries
Flow control, VLAN support, auto-uplink (auto MDI/MDI-X), port mirroring, Broadcast Storm Control, half duplex mode, full duplex mode, Quality of Service (QoS)
IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
9.4 cm x 10.4 cm x 2.8 cm
300 g
Microsoft Windows Vista / XP
United Kingdom
NETGEAR lifetime warranty
Switch - 5 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
5 x 10/100/1000
4K entries
Status Indicators
Port transmission speed, power, link/activity
5 x 1000Base-T RJ-45
External power adapter
4 Watt
Mounting Kit
Included
MTBF
5,905,968 hours
C-Tick, VCCI Class B ITE, CISPR 22 Class B, cUL, UL 1950, EN55022 Class B, CB, FCC Part 15 B
United Kingdom
Software Included
Drivers & Utilities
9.4 cm
10.4 cm
2.8 cm
300 g
50 °C
0 - 90%
Resources
The following resources are available for the NETGEAR ProSafe Plus Switch 5-port Gigabit Ethernet
