NetGear PowerLINE WiFi 1000 802.11b/g/n/ac Dual Band
Quicklinx: BW7ZWS00 Mfr#: PLW1000-100UKS
  • IEEE 802.11n
The NETGEAR PLW1000 AV 1000 Powerline/HomePlug Starter Kit can use your existing electrical wiring to extend your WiFi and Internet access to any room in your house. Just plug a Powerline Adapter into your modem or router, then plug in the companion Powerline WiFi access point to an electrical outlet. It’s that easy. With 1000 Mbps speed and Homeplug AV2 support, the NETGEAR PLW1000 is perfect for connecting smart TVs, streaming players, and game consoles wirelessly.
  • Seamless connectivity
    Experience uninterrupted Internet with the NETGEAR Powerline PLW1000, offering both wired and wireless connectivity options. With support for Ethernet, Fast Ethernet, and Gigabit Ethernet alongside HomePlug AV 2.0, this powerline adapter kit ensures a stable and fast connection for all your devices.
  • Dual-band advantage
    The PLW1000 operates on both 2.4 GHz and 5 GHz bands, allowing for a more reliable connection by minimizing interference and maximizing speed, catering to all your streaming, gaming, and browsing needs.
  • Easy setup
    Designed for convenience, the NETGEAR Powerline PLW1000 is wall-pluggable and comes with a simple setup process. It's compatible with both Mac and PC, ensuring a wide range of device support without the need for complex installation procedures.
NETGEAR Powerline PLW1000 - powerline adapter kit - Wi-Fi 5 - wall-pluggable - with NETGEAR PowerLINE 1000 Adapter (PL1000)
Powerline adapter kit - with NETGEAR PowerLINE 1000 Adapter (PL1000)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1 Gbps
IEEE 802.3, HomePlug AV 2.0, IEEE 1901
AC 120/230 V
8.7 cm x 3.8 cm x 12.1 cm
266 g
Apple MacOS X, Microsoft Windows Vista / XP / 7 / 8
United Kingdom
1-year warranty
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1 Gbps
1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 1 x HomePlug AV 2.0
Internal power supply
AC 120/230 V
5 Watt
2 x network cable - 2 m
United Kingdom
8.7 cm
3.8 cm
12.1 cm
266 g
Limited warranty - 1 year , Technical support - 90 days
