Nighthawk X4S AC2600 Wi-Fi VDSL/ADSL modem router with MU-MIMO and Quad Stream technology delivers Wi-Fi to multiple devices simultaneously for faster speeds. Get ultimate Wi-Fi speeds, with a powerful processor. Enjoy smoother streaming and gaming by prioritizing application and device with Dynamic QoS.
Wave 2 MU-MIMO technology
When multiple devices are connected to the router, each device needs to take its turn and then wait before receiving more data. This leads to slower network and Internet speeds. MU-MIMO technology delivers high-speed data streams to up to three devices simultaneously, so there's less waiting, boosting overall network speeds for all Wi-Fi devices. -
Dynamic QoS
Reduce buffering and lag while gaming or streaming. Based on an advanced application and device aware prioritization technology, Dynamic QoS intelligently allocates bandwidth to the most important activities in your home. -
Powerful processors
Make sure you have enough processing power to run all the network-heavy applications throughout your connected home. With an unmatched processor, you'll have unparalleled performance for gaming, streaming and mobile connectivity. -
Built for gaming, streaming and mobility
Take gaming and streaming to the advanced level. Multi-user MIMO (MU-MIMO) and Quad Stream technology delivers Wi-Fi to multiple devices simultaneously for faster speeds while Dynamic QoS prioritizes Internet traffic by application and device for lag-free connections. Roam freely on your mobile devices with increased range from Quad-Stream Wave 2 Wi-Fi. Beamforming+ and four high-powered antennas and amplifiers increase coverage, dependability and performance. -
Storage
The twin USB 3.0 ports and eSATA port provide speed and flexibility when you connect your external storage to your Nighthawk X4S. Enjoy fast, wireless access to your high-capacity hard drives from anywhere.
- NETGEAR Nighthawk X4S AC2600 - wireless router - DSL modem - Wi-Fi 5 - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL, VDSL, ADSL2, ADSL2+, VDSL2
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 2.53 Gbps
- Remote Management Protocol
- HTTP
- Firewall protection, NAT support, VPN support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), FTP server, ReadySHARE, Push ‘N’ Connect button, DLNA Media Server, Beamforming+, MU-MIMO technology
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- 28.5 cm x 18.5 cm x 5 cm
- 840 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8
- Localisation
- United Kingdom
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 2.53 Gbps
- HTTP
- Encryption Algorithm
- WPA, WPA2
- Wi-Fi Rating
- AC2600
- Processor
- 1 x 1.4 GHz
- RAM
- 512 MB
- Flash Memory
- 128 MB
Line Properties
- Line Coding Format
- 256 QAM
Communications
- DSL modem
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 2 x 9 pin USB Type A , Phone line: 1 x VDSL2 / ADSL2+ - RJ-11 , Storage: 1 x eSATA - 7 pin external Serial ATA
Aerial
- Aerial
- External detachable
- Antenna Qty
- 4
- Power Device
- External power adapter
- Included Accessories
- POTS filter
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- Software Included
- NETGEAR Genie
- OS Required
- 28.5 cm
- 18.5 cm
- 5 cm
- 840 g
- Technical support - phone consulting - 90 days
