The NETGEAR Next-Gen Edge M5300 series consists of three fully managed, stackable Gigabit Ethernet switches, with embedded 10 Gigabit Ethernet uplink connectivity. There are 24-port and 48-port models including Gigabit copper versions, and a Fiber aggregation solution. They are ideal for all organizations considering reliable, affordable and simple 10 Gigabit Ethernet backbone architectures. As a proficient component of converged voice, video and data networking solutions, NETGEAR M5300 series delivers a resilient access layer in server rooms for virtualization, campus LAN environments and commercial buildings. Virtual Chassis stacking technology - including meshed stacking - scales both the entire network's performance and its redundancy.
- Netgear Next-Gen Edge Managed Switch M5300-28G - switch - 24 ports - rack-mountable
- Switch - 24 ports - stackable
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- 20 x 10/100/1000 + 4 x combo SFP + 2 x combo SFP/SFP+
- Performance
- Bandwidth: 136 Gbps
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 12KB
- Remote Management Protocol
- SNMP 1, SNMP 2, RMON 1, RMON 2, RMON 3, RMON 9, SNMP 3, SSH, SSH-2
- Flow control, Layer 2 switching, BOOTP support, ARP support, IGMP snooping, Syslog support, DiffServ support, MAC address filtering, Broadcast Storm Control, SNTP support, Weighted Random Early Detection (WRED), Spanning Tree Protocol (STP) support, Multiple Spanning Tree Protocol (MSTP) support, Quality of Service (QoS), SSH support, DHCP server, MLD snooping, DHCP relay, Link Aggregation Control Protocol (LACP), Port Security, DHCP client, Multicast VLAN Registration (MVR), Ring Rapid Spanning Tree Protocol (RRSTP), Class of Service (CoS)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.3ae, IEEE 802.1s, IEEE 802.3ak, IEEE 802.3an, IEEE 802.3aq, IEEE 802.3az
- 44.5 cm x 39.2 cm x 4.2 cm
- 6.3 kg
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Gigabit Ethernet
- Ports
- Performance
- 32K entries
- 12KB
- Encryption Algorithm
- TLS 1.0, SSL 3.0
- Authentication Method
- Secure Shell (SSH), RADIUS, TACACS+, Secure Shell v.2 (SSH2)
- Status Indicators
- Port status, power, link/activity
- 20 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , 4 x 100Base-TX/1000Base-T - RJ-45 , 4 x SFP (mini-GBIC) , 2 x 10Gb Ethernet / 1Gb Ethernet - RJ-45 , 2 x 10Gb Ethernet / 1Gb Ethernet - SFP+ , 1 x console - mini-USB Type B , 1 x console - 9 pin D-Sub (DB-9) , 1 x USB Type A
- Power Device
- Internal power supply
- Installed Qty
- 1
- 55 Watt
- Rack Mounting Kit
- Included
- CISPR 22 Class A, cUL, EN 60950, IEC950, UL 1950, VCCI Class A ITE, EN55024, EN55022 Class A, EN50082-1, FCC Part 15 A, C-Tick Class A
- 44.5 cm
- 39.2 cm
- 4.2 cm
- 6.3 kg
- 0 °C
- 50 °C
- 0 - 90% (non-condensing)
- Min Storage Temperature
- -20 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 0 - 95% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
