The NETGEAR AC750 Wi-Fi modem router upgrades your Wi-Fi to support AC devices and provides Wi-Fi speeds of up to 300+450 Mbps. This DSL modem router with built-in ADSL2+ modem offers ReadySHARE USB for wireless access & sharing of USB hard drives & printers. It also includes Gigabit Ethernet WAN for fiber connections and NETGEAR genie home network manager for easy installation and home network management.
- NETGEAR D6000 - wireless router - DSL modem - Wi-Fi 5 - desktop
- Wireless router - DSL modem - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 750 Mbps
- Remote Management Protocol
- HTTP
- Firewall protection, auto-sensing per device, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, firmware upgradable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), ReadySHARE, Live Parental Controls, Push ‘N’ Connect button, reset button
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, IEEE 802.11ac
- 24 cm x 18.2 cm x 4.1 cm
- 393 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
- Localisation
- United Kingdom
- 2-year warranty
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 750 Mbps
- HTTP
- Encryption Algorithm
- WPA-PSK, WPA2-PSK
- RAM
- 64 MB
- Flash Memory
- 16 MB
Communications
- DSL modem
- ADSL2+
- LAN: 3 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x ADSL2+ - RJ-11 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Power Device
- External power adapter
- Included Accessories
- POTS filter
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- OS Required
- 24 cm
- 18.2 cm
- 4.1 cm
- 393 g
- Limited warranty - 2 years
