The NETGEAR N300 Wi-Fi Modem Router - Essentials Edition has a built-in ADSL2+ modem for use with DSL, cable or fiber Internet service. With external antennas for improved Wi-Fi coverage, this modem router delivers high-performance speeds of up to 300 Mbps and is an ideal modem router for medium-sized homes. The N300 Wi-Fi Modem Router delivers the speed and reliability needed for simultaneous downloads, online gaming and a secure and reliable connection to the Internet. It includes features such as Ethernet WAN for easy upgrade to cable or fiber.
Speed
Speed makes video streaming better. Speed makes online gaming more fun. Speed makes all your devices really go. And anyplace you need speed, with NETGEAR you got it. Fast download speeds up to N300 Mbps. Everything you need for a fast connected home. -
Wi-Fi range
Homes come in all shapes and sizes. The NETGEAR Wi-Fi range N300 Wi-Fi Modem Router - Essentials Edition provides Wi-Fi connectivity throughout your home for all your Internet-enabled devices. -
Reliable connections
Stay connected - with your devices, your media, and your friends. The N300 Wi-Fi Modem Router has external antennas that provide improved coverage and throughput. -
Sharing
Relive memories and share them with others. If it's secure and shared storage access you want NETGEAR has easy ways to do it. -
Ease of use
NETGEAR makes it easy to do more with your digital devices. The simple browser-based installation with no CD makes router installation easy using an iPad, tablet, smartphone, or computer. -
Security
Keep your Internet browsing experience safe and secure with Wi-Fi connections that offer the highest level of WPA/WPA2 security. -
Applications
With this router, you can create a home network for applications such as online gaming, with a fast reliable connection to the Internet and a secure wireless connection.
- NETGEAR D1500 - Essentials Edition - wireless router - DSL modem - Wi-Fi - desktop
- Wireless router - DSL modem - 2-port switch (integrated)
- Enclosure Type
- Desktop
- Digital Signaling Protocol
- ADSL2+
- WAN Ports Qty
- 2
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- DoS attack prevention, Intrusion Detection System (IDS), IPv6 support, firmware upgradable
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- 16.6 cm x 10 cm x 2.8 cm
- 141 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7, Windows 8
- Localisation
- United Kingdom
- 2-year warranty
- Wireless router - 2-port switch (integrated)
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK
Communications
- DSL modem
- ADSL2+
- LAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x ADSL2+ - RJ-11
Aerial
- Aerial
- External integrated
- Antenna Qty
- 2
- Power Device
- External power adapter
- Included Accessories
- POTS filter
- Cables Included
- 1 x network cable , 1 x phone cable
- Localisation
- United Kingdom
- OS Required
- 16.6 cm
- 10 cm
- 2.8 cm
- 141 g
- Limited warranty - 2 years
