Boost performance indoors or in fringe network areas by plugging this external antenna into your 3G/4G AirCard modem or mobile hotspot. This antenna is designed to increase speeds and extend coverage when in buildings, vehicles, or remote sites where network coverage is sparse. Simple installation, no software required.
Enhanced connectivity
Designed for indoor use, the NETGEAR AirCard antenna ensures reliable connectivity with its MIMO technology, optimizing signal strength and quality for your LTE and 3G devices. -
Versatile compatibility
With a broad frequency range covering 700 - 2700 MHz, this antenna is compatible with a wide array of cellular networks, ensuring you stay connected wherever you are. -
Effortless installation
Featuring a 1 m cable and convenient bill clips, the antenna is easy to place and mount indoors, making it an ideal solution for enhancing signal reception without the need for professional installation.
- NETGEAR AirCard antenna
- Product Type
- Antenna
- 12 cm x 16 cm x 0.55 cm
- Intended For
- Cellular
- Aerial Placing / Mounting
- Indoor
- Compatibility
- LTE
- Frequency Range
- 1710 - 1990 MHz, 2110 - 2170 MHz, 700 - 906 MHz, 2500 - 2700 MHz
- Gain
- 2.5 dBi
- Designed For
- AirCard AC762S, AC785
- Product Type
- Antenna
- 12 cm
- 16 cm
- 0.55 cm
- Cable Length
- 1 m
Aerial
- Intended For
- Cellular
- Indoor
- Compatibility
- LTE
- Frequency Range
- Gain
- 2.5 dBi
Cabling & Wiring
- Connector Provided
- 2 x TS-9 male
- MIMO technology, bill clips
- Designed For
- NETGEAR AirCard AC762S, AC785
