NetGear ProSafe 1000Base-T SFP RJ45 GBIC
LIFETIME WARRANTY
Quicklinx: 7VRPWS00 Mfr#: AGM734-10000S
Type: Modules
£106.73 ex VAT
£128.07 inc VAT
The ProSAFE GBIC Module fits into standard SFP slots and drives Gigabit Ethernet up to 100m distances with CAT5E/CAT6.
  • Enhanced connectivity
    The NETGEAR ProSafe AGM734 features an RJ-45 connector, providing reliable and high-speed Ethernet 1000Base-T connectivity. This ensures seamless integration into existing network infrastructures, offering a straightforward solution for upgrading network performance.
  • High-speed performance
    With a data transfer rate of 1 Gbps, this SFP (mini-GBIC) transceiver module is designed to meet the demands of Gigabit Ethernet networks. It supports fast data link protocols, enabling efficient and rapid data transmission across the network.
  • Easy installation
    The plug-in module form factor of the NETGEAR ProSafe AGM734 allows for easy installation, making it a convenient choice for expanding network capabilities without the need for complex setup procedures.
NETGEAR ProSafe AGM734 - SFP (mini-GBIC) transceiver module - 1GbE
SFP (mini-GBIC) transceiver module - RJ-45
Plug-in module
Cabling Type
1000Base-T
Data Transfer Rate
1 Gbps
1GbE
P/N: GS724TPP-300EUS
Plug-in module
Wired
Cabling Type
1000Base-T
1GbE
Data Transfer Rate
1 Gbps
1 x Ethernet 1000Base-T - RJ-45
Compatible Slots
1 x SFP (mini-GBIC)
Type: Modules
Brand: NETGEAR
