NETGEAR AC1600 Smart WiFi Router -Dual Band
Quicklinx: DF3MWS00 Mfr#: R6260-100UKS
  • IEEE 802.11n
The NETGEAR AC1600 smart Wi-Fi router is an incredibly fast router delivering high Wi-Fi and Gigabit Ethernet speeds. External antennas provide improved Wi-Fi coverage for larger homes. It avoids wireless interference, ensuring top Wi-Fi speeds and reliable connections. Ideal for applications such as lag-free multiple video streaming, multi-player gaming, ultra-fast speed and a secure and reliable connection to the Internet.
  • Wide Wi-Fi range
    The NETGEAR AC1600 smart Wi-Fi router provides Wi-Fi connectivity throughout your home for all your Internet-enabled devices.
  • Reliability
    There's nothing more frustrating than lost connections! With NETGEAR's advanced features & technology, you'll reduce interference & enjoy more reliable Wi-Fi connectivity.
  • Easy sharing
    With NETGEAR, sharing across your network is fun and easy, anything from accessing stored photos & music.
  • Ease of use
    Start enjoying your device faster than ever. NETGEAR wants to make sure installation and management is simple & easy, so you can connect quickly & make sure you stay that way!
NETGEAR R6260 - wireless router - Wi-Fi 5 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Auto-sensing per device, SPI, DoS attack prevention, IPv6 support, parental control, WPS, FTP server, ReadySHARE, reset button, DLNA support, guest access, Advanced QoS, Circle Smart Parental Controls
23.551 cm x 15.076 cm x 5.45 cm
340 g
UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
United Kingdom
1-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Encryption Algorithm
WPA-PSK, WPA2-PSK
Wi-Fi Rating
AC1600
880 MHz
RAM
128 MB
Flash Memory
128 MB
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin mini-USB Type A
External power adapter
1 x network cable
United Kingdom
23.551 cm
15.076 cm
5.45 cm
340 g
Limited warranty - 1 year
