NETGEAR AC WiFi Business Access Point with Insight app for easy managment
Quicklinx: D577WS00 Mfr#: WAC505-10000S
  • IEEE 802.11n
The NETGEAR Insight Managed Wireless Access Point WAC505 delivers high performance WiFi and high client density for enterprises requiring ubiquitous and reliable wireless for all business applications. The WAC505 is managed by NETGEAR Insight app, for a more intuitive and innovative support, with no need for extra management hardware. The WAC505 features Multi-User MIMO (MU-MIMO) to achieve aggregate speeds up to 1.2 Gbps, option to configure as or Access Point modes, and comes with two Ethernet ports, a Power-over-Ethernet (PoE) 1Gb LAN port and a WAN port.
NETGEAR WAC505 - radio access point - Wi-Fi 5
Radio access point
External
Worldwide (excluding United States and Canada)
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac Wave 2
Frequency Band
2.4 GHz, 5 GHz
Performance
Aggregate throughput: 1.2 Gbps , Maximum throughput (2.4 GHz): 300 Mbps , Maximum throughput (5 GHz): 867 Mbps
Wall mounting kit, ceiling mounting kit
Power Over Ethernet (PoE) Supported
PoE
17.5 cm x 16.5 cm x 3.5 cm
256 g
5-year warranty
Radio access point
17.5 cm
16.5 cm
3.5 cm
256 g
External
Wired
Network / Transport Protocol
Bonjour
Remote Management Protocol
SNMP 1, SNMP 2c, SSH
Frequency Band
2.4 GHz, 5 GHz
Performance
Status Indicators
Power, WLAN, LAN, link/activity
VPN support, VLAN support, auto-uplink (auto MDI/MDI-X), repeating mode, manageable, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, Wi-Fi Multimedia (WMM) support, Multiple SSID support, wireless bridge mode, 2T2R MIMO technology, LLDP support, Management Information Base (MIB), 802.1x authentication, Transmit Power Control (TPC), MAC address authentication
Encryption Algorithm
SSL, WPA, WPA2
Authentication Method
Secure Shell (SSH)
IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11i, IEEE 802.11n, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.11ac Wave 2
Aerial
Antenna
Internal
1 x 1000Base-T (PoE) - RJ-45 (WAN)
PoE
8.9 Watt
Limited warranty - 5 years
