NETGEAR WiFi 6 WAX204 Access Point
Quicklinx: GCZMWS00 Mfr#: WAX204-100EUS
  • IEEE 802.11n
The NETGEAR Wi-Fi 6 AX1800 Dual Band Wireless Access Point (AP) delivers 802.11ax high performance wireless connectivity for Small Office and Home Office (SOHO) deployments and supports dual band concurrent Wi-Fi 6 operations at 2.4GHz and 5GHz with a combined throughput of 1.8Gbps (600Mbps at 2.4GHz and 1200Mbps at 5GHz). The WAX204 Wi-Fi 6 Access Point provides standalone configuration with easy setup for a reliable, 802.11ax high performance, and cost-effective wireless solution.
  • Enhanced connectivity
    With dual-band support, the NETGEAR WAX204 offers a 2.4 GHz band for extended range and a 5 GHz band for high-speed Internet access, ensuring optimal performance for various devices and applications.
  • Robust security
    Equipped with WPA, WPA2, and WPA3 encryption algorithms, this wireless access point provides a secure connection, protecting sensitive data from unauthorized access.
  • High capacity
    Designed to support up to 256 clients, the NETGEAR WAX204 is suitable for busy environments, offering reliable service without compromising speed or quality.
  • Versatile performance
    Featuring a maximum throughput of 600 Mbps on the 2.4 GHz band and 1.2 Gbps on the 5 GHz band, the WAX204 delivers fast and efficient wireless connectivity, catering to all your Internet needs.
  • Easy management
    With features like Quality of Service (QoS), VPN passthrough, and Wi-Fi Multimedia (WMM) support, managing your network's performance and prioritizing traffic becomes effortless.
NETGEAR WAX204 - radio access point - Wi-Fi 6
Radio access point
Desktop
Ports Qty
5
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax
Frequency Band
2.4 GHz, 5 GHz
Performance
Maximum throughput (2.4 GHz): 600 Mbps , Maximum throughput (5 GHz): 1.2 Gbps
Maximum number of clients: 256 , SSIDs total: 3
23.6 cm x 18.4 cm x 5.7 cm
490 g
3-year warranty
Radio access point
23.6 cm
18.4 cm
5.7 cm
490 g
Desktop
Ports Qty
5
Wireless
Frequency Band
2.4 GHz, 5 GHz
Performance
Wi-Fi Rating
AX1800
Status Indicators
Power, LAN, wireless, WPS, Internet
Auto-uplink (auto MDI/MDI-X), MAC address filtering, VPN passthrough, Wi-Fi Multimedia (WMM) support, Access Control List (ACL) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), reset button, SOHO (Small Office/Home Office)
Encryption Algorithm
WPA, WPA2, WPS, WPA3
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11e, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
Aerial
Antenna
External
Antenna Qty
3
Gain Level
3 dBi
4 x 1000Base-T - RJ-45 , 1 x 1000Base-T - RJ-45 (WAN)
1 x network cable
MTBF
1,970,213.9 hours
EN 60950
External power adapter
Installed Qty
1
Power Provided
18 watt
Limited warranty - 3 years , Technical support - 90 days
10 - 90%
