Hang on - your network will soar when it's hooked up to NETGEAR's FS605!
This powerful plug-and-play switch connects at 10 or 100 Mbps and makes it easy to link as many as five computers or peripherals to your Ethernet network.
You'll experience maximum performance for 10 or 100 Mbps devices with five ports that automatically sense the correct speed while Auto Uplink on the ports adjusts for the different types of Ethernet cables. The FS605's sleek case has lights on the front for easy monitoring. Installation into your home network couldn't be simpler and, once powered on, it begins cool and silent operation - without an internal fan.
Auto Uplink™ technology automatically adjusts to suit all your Ethernet cables
Every port automatically senses the right speed and duplex mode
Low power consumption, enabling these switches to run cool without a fan
Works with PCs, Macs, servers, printers & virtually any Ethernet device
Attractive, compact platinum design blends seamlessly into your home decor
Network Connectivity: 5 RJ-45 ports for 10BASE-T and 100BASE-TX
Status LEDs: Power, Speed and activity on each port
- NETGEAR FS605 - switch - 5 ports
- Switch - 5 ports
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- MAC Address Table Size
- 1K entries
- Flow control, full duplex capability, MDI/MDI-X switch, auto-negotiation, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3x
- 17.5 cm x 11.8 cm x 2.8 cm
- 0.3 kg
- System Requirements
- Apple MacOS, Novell NetWare, Linux, Microsoft Windows
- 3-year warranty
- Switch - 5 ports
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- 5 x 10/100
- 1K entries
- Status Indicators
- Port transmission speed, power, link/activity
- 5 x 100Base-TX RJ-45
- Power Device
- External power adapter
- 3.7 Watt
- Mounting Kit
- Included
- FCC Class B certified, TUV, C-Tick
- OS Required
- 17.5 cm
- 11.8 cm
- 2.8 cm
- 0.3 kg
- Technical support - phone consulting - response time: 24/7 hours a day / days a week , Limited warranty - 3 years , Technical support - e-mail consulting - response time: 24/7 hours a day / days a week
- 0 °C
- 40 °C
- 0 - 90%
Customer reviews
Write a review for the NETGEAR 5-Port 10/100 Switch here!
Great Network Switch
Reviewed by Lee Thomas. Review Posted 21/07/2007
Great for extending your network with no hassle.
Just ordered the 4th
Overall
Ease of use
Value for money
good value stylish swtich
Reviewed by Anonymous Review Posted 28/11/2003
good switch. nice design.
has mount so you can mount it vertically.
only has data transfer lights (no duplex/full duplex) lights.
apart from that.. no complaints.
running 24/7 no probs for nearly a year.
Overall
Ease of use
Value for money
great switch
Reviewed by Anonymous Review Posted 20/05/2004
Top quality switch. I've currently been running it 24/7 for over 6 months with absolutely no problems. Transferred over 20Tb with this switch as part of a 100Mbit campus network. Would strongly recommend.
Overall
Ease of use
Value for money
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
