The NETGEAR AC1900 Dual Band Gigabit Wi-Fi Router delivers extremely fast Wi-Fi. With AC1900 Wi-Fi, Gigabit Ethernet speeds, and high-power radio amplifiers, this router offers ultimate performance in wireless coverage for large homes with 20 or more wireless devices. It gets 3x faster access than similar 802.11n technology and more reliable streaming for home computers and mobile devices. This router delivers the ultra-fast speed and reliability needed for applications such as smooth, lag-free multiple HD video streaming, multi-player gaming, and a secure and reliable connection to the Internet. The AC1900 Dual Band Gigabit Wi-Fi Router also includes NETGEAR genie home network manager for home network management.
Compatible with next-generation Wi-Fi devices and backward compatible with 802.11 a/b/g/n devices, it enables HD streaming throughout your home. With up to 600+1300 Mbps speed and simultaneous dual band Wi-Fi technology, this router avoids wireless interference, ensuring ultimate connectivity for the latest dual band Wi-Fi devices such as smartphones, tablets, smart TVs, etc. In addition, Beamforming+ technology boosts speed, reliability and range of Wi-Fi connections, while the USB 3.0 port provides up to 10x faster USB hard drive access.
Enhanced connectivity
With dual-band support, the NETGEAR R6800 offers a seamless Internet experience by operating on both 2.4 GHz and 5 GHz bands. This flexibility ensures optimal performance for a wide range of online activities, from streaming high-definition content to online gaming. -
Robust security
Equipped with advanced encryption standards including WPA, WPA-PSK, WPA2, and WPA2-PSK, the NETGEAR R6800 provides a secure and private connection. This, combined with features like DoS attack prevention and Stateful Packet Inspection (SPI), safeguards your network against unauthorized access and threats. -
High-speed performance
The NETGEAR R6800 boasts a data transfer rate of up to 1.9 Gbps, supported by 3T3R MIMO technology and Beamforming+. These features enhance the speed and reliability of your wireless connection, ensuring smooth streaming, gaming, and downloading across multiple devices. -
Convenient file sharing
With both USB 2.0 and USB 3.0 ports, the NETGEAR R6800 facilitates easy sharing of files and media across the network. ReadySHARE and ReadyCLOUD provide additional options for easy access and sharing of USB storage remotely. -
Smart parental controls
Circle Smart Parental Controls allow for the management and monitoring of network usage with ease. Set online time limits, filter websites, and maintain control over your family's online experience without compromising on speed or connectivity.
- NETGEAR R6800 - wireless router - Wi-Fi 5 - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 1.9 Gbps
- FTP
- Auto-sensing per device, NAT support, Stateful Packet Inspection (SPI), DoS attack prevention, IPv6 support, parental control, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), FTP server, ReadySHARE, Push ‘N’ Connect button, 3T3R MIMO technology, on/off switches, Beamforming+, ReadyCLOUD, Circle Smart Parental Controls
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, DLNA CERTIFIED, IEEE 802.11ac
- 28.5 cm x 18.3 cm x 6.2 cm
- 709 g
- System Requirements
- UNIX, Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/10
- Localisation
- United Kingdom
- 2-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 1.9 Gbps
- FTP
- Encryption Algorithm
- WPA, WPA2, WPA-PSK, WPA2-PSK
- RAM
- 256 MB
- Flash Memory
- 128 MB
- Status Indicators
- Status
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A , USB 3.0: 1 x 9 pin USB Type A
Aerial
- Aerial
- External detachable
- Antenna Qty
- 3
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- OS Required
- 28.5 cm
- 18.3 cm
- 6.2 cm
- 709 g
- Limited warranty - 2 years
