NETGEAR 100/1G/2.5G/5G/10Gbase-T Sfp+Module
Quicklinx: D9QPWS00 Mfr#: AXM765-10000S
£264.57 ex VAT
£317.48 inc VAT
The NETGEAR 10GBASE-T SFP+ Transceiver (AXM765) delivers 10G copper connectivity with CAT6a or CAT7 cabling up to 30 meters (98.5 feet) when inserted in a switch SFP+ fiber module slot. The AXM765 fits into SFP+ interfaces of M4300, M5300, M6100, M7100 and M7300 Managed Switches, as well as select Smart Managed Pro and Plus Switches. Compatible with the IEEE 802.3an/bz standard, AXM765 delivers Multi-Gigabit copper connectivity with CAT5e or CAT6 cabling up to 100 meters (92.8 feet) when inserted in Multi-Gigabit SFP+ fiber module slot, or Gigabit copper connectivity when inserted in Gigabit SFP fiber module slot.
  • High-speed connectivity
    Experience fast data transfer rates of up to 10 Gbps with the NETGEAR AXM765. This SFP+ transceiver module ensures quick and efficient handling of large data volumes, making it suitable for high-bandwidth applications.
  • Extended reach
    With a maximum transfer distance of 100 m, the NETGEAR AXM765 offers flexibility in network design and deployment, allowing for efficient connectivity across extended distances within your network infrastructure.
  • Robust compatibility
    Designed to meet the IEEE 802.3an and IEEE 802.3bz standards, this module is compatible with a wide range of Ethernet 10GBase-T networking equipment, ensuring a smooth and seamless integration into your existing network.
NETGEAR AXM765 - SFP+ transceiver module - 10GbE
SFP+ transceiver module - RJ-45
Plug-in module
Cabling Type
10GBase-T
Data Transfer Rate
10 Gbps
10GbE
Max Transfer Distance
100 m
5-year warranty
Plug-in module
Wired
Cabling Type
10GBase-T
10GbE
Data Transfer Rate
10 Gbps
100 m
IEEE 802.3an, IEEE 802.3bz
1 x Ethernet 10GBase-T - RJ-45
Limited warranty - 5 years
Brand: NETGEAR
