Powerful and versatile soundbar using FreeStyle design, V16 and S12 speakers designed by Peter Larsen. Dynamic sound effects projection and full range acoustic spectrum with accuracies and clarity.
High fidelity system with quality and precision technology from Microlab well-known sound craftsmen.
Ideal for LCD TVs and home movie/music entertainment
Features:
- Powerful Soundbar speaker systems for LCD TV
- Powerful 3" woofer and full range drivers for Home theater effects designed by Peter Larsen
- 2.2 speaker system with S12 woofers and dual V16 tweeters; specially designed long-throw woofer driver
- Top panel controls and LED display
- Microlab eAirbass technology for firmer depth and resolution
Technical Specifications:
Amplifier:
Output power: 28 Watt RMS
Power distribution: 7 Watt x 2 + 7 Watt x 2
Harmonic distortion: < 0.3% 1W 1kHz
Frequency response: 40Hz - 70kHz
Signal/Noise ratio: > 80dB
Separation: > 50dB
Input sensitivity: 500mV
Nominal impedance: 4 ohm
Crossover: 350Hz
Speakers:
Tweeter driver type: 2.5"
Tweeter rated power: 10 Watt 4 ohm
Bass driver type: 3" x 2
Bass rated power: 15 Watt 4 ohm
Frequency range: 30Hz - 75kHz
Interfaces:
Output: 2RCA sockets
Input: 2RCA
Power:
Power supply: AC 220V - 240V ~ 50Hz 210mA
Fuse: T400mAL250V
Package Contents:
S325 soundbar
2RCA - 2RCA cable
User manual
Dimensions:
Product dimension: 860 x 122 x 150mm
Product net weight: 6.50kg
Giftbox dimension: 977 x 205 x 177mm
Giftbox gross weight: 7.3kg
Export carton dimension: 988 x 217 x 374mm
Export carton gross weight: 15.7kg
- Microlab Soundbar S325 - sound bar - for home theatre
- Product Type
- Sound bar - for home theatre
- Speaker Type
- 2-way - active
- Nominal Output Power (Total)
- 25 Watt
- Frequency Response
- 30 - 75000 Hz
- Amplifier
- Integrated
- Speaker Details
- Sound bar - stereo x 2 - 4 Ohm - active
- Power
- AC 230V (50 Hz)
- 86 cm x 12.2 cm x 15 cm
- 6.5 kg
- Product Type
Speaker System
- Speaker Type
- 2-way - active
- Audio System Continuous Power (Total)
- 25 Watt
- 30 - 75000 Hz
- Total Harmonic Distortion
- 0.3%
- Crossover Frequency
- 350Hz
- Amplifier
- Integrated
Speaker System Details
- Speaker Details
- Driver Details
- Sound bar: 2 x woofer driver - 3" , Sound bar: full-range driver - 2.5"
- Connector Type
- Audio input (RCA x 2) , Audio output (RCA x 2)
- Included Accessories
- Audio cable
- Power Source
- AC power adapter
- Voltage Required
- AC 230V (50 Hz)
- 86 cm
- 12.2 cm
- 15 cm
- 6.5 kg
