A beautifully designed 2.1 subwoofer speaker system with a stunning black finishe. Ideal for use with digital multimedia and computer systems. Experience a full range of audio and deeper bass within the wooden subwoofer cabinet. The satellite speakers are in stands for perfect optimum listening position.
Designed by Microlab's Danish chief consultant, Peter Larsen - speaker design with perfect acoustic production.
Features:
- Powerful 2.1 subwoofer system with full range acoustic performances in depth and resolution.
- Ideal for digital multimedia and computer applications
- Unique designed 5" subwoofer for deep bass and strong vocal clarity
- Wired remote volume control with 3.5mm stereo jack for direct input and output to headphones
- Magnetically shielded for interference free positioning
Technical Specifications:
Amplifier
Output power: 40 Watt RMS
Power distribution: 12 Watt x 2 + 16 Watt
Harmonic distortion: < 0.3% 1W 1kHz
Frequency response: 35Hz - 20kHz
Signal/Noise ratio: > 80dB
Separation: > 45dB
Input sensitivity: 400mV
Nominal impedance: 6 ohm
Speakers:
Tweeter driver type: 2.5"
Tweeter rated power: 10 Watt
Bass driver type: 5"
Bass rated power: 15 Watt
Frequency range: 35Hz - 20kHz
Interfaces:
Output: 2RCA sockets
Input: 2RCA sockets
- Microlab M-200 - speaker system - for PC
- Product Type
- Speaker system - for PC - 2.1-channel
- System Components
- 2 speakers, subwoofer
- Speaker Type
- Active
- Nominal Output Power (Total)
- 40 Watt
- Frequency Response
- 40 - 20000 Hz
- Amplifier
- Integrated
- Speaker System Details
- 1 x subwoofer , 2 x satellite speaker
- Product Type
Speaker System
- System Components
- Speaker Type
- Active
- Audio System Continuous Power (Total)
- 40 Watt
- 40 - 20000 Hz
- Signal-To-Noise Ratio
- 80 dB
- Amplifier
- Integrated
- Speakers Included
- 1 x subwoofer - wired , 2 x satellite speaker - wired
- Driver Details
- Subwoofer: subwoofer driver - 5"
- Driver Details (2nd speaker)
- Satellite speaker: full-range driver - 2.5"
- Power Source
- AC power adapter
- Dimensions (WxDxH) / Weight Details
- Satellite speaker: 9 cm x 17 cm x 9 cm , Subwoofer: 27 cm x 18.9 cm x 15.6 cm
