Microlab FineCone FC360 - 5.1-channel PC multimedia speaker system - 100 Watt (Total)
Quicklinx: 7ZH6WS00 Mfr#: MICROLABFC360-5.1
5.1 speakers system with powerful amplifier for your home theater
Enjoy movie audio effects from the comfort of your own home with 5 satellites and a subwoofer. This system places satellite speakers around your room and creates a dynamic surround effects with your movie sound production. Comes with remote control for convenience.
Features:
Powerful home theater 5.1 surround subwoofer system with full range acoustic production and surround satellites
6.5" woofer system for deep vocal and bass effects
All magnetically shielded for safe positioning near TV
Standalone amplifier with full front controls and includes wireless remote control
Technical Specifications:
Amplifier:
Output power: 100 Watt RMS
Power distribution: 14 Watt x 5 + 30 Watt
Harmonic distortion: < 0.3% 1W 1kHz
Frequency response: 30Hz - 20kHz
Signal/Noise ratio: > 70dB
Separation: > 40dB
Input sensitivity: 380mV
Nominal impedance: 4 ohm
Speakers:
Tweeter driver type: 2.5"
Tweeter rated power: 14 Watt
Bass driver type: 6.5"
Bass rated power: 30 Watt
Frequency range: 30Hz - 20kHz
Interfaces:
Output: RCA sockets
Input: RCA sockets
Power:
Power supply: AC 220 - 240V, 50Hz, 380mA
Fuse: T800mAL250V
Includes Remote control
Package Contents:
FC360 5.1 subwoofer
FC360 5.1 amplifier
FC360 satellites x 4
FC360 center satellite
2RCA - 2RCA cables x 3
3.5mm stereo - 2RCA cable
Infrared remote control
User manual
Dimensions:
Subwoofer dimension: 255 x 255 x 287 mm
Satellites dimension: 88 x 200 x 102 mm
Center Satellites dimension: 230 x 88 x 102 mm
Amplifier dimension: 96 x 252 x 310 mm
Product net weight: 14.5 kg
Giftbox dimension: 500 x 373 x 398 mm
Giftbox gross weight: 15.4 kg
Export carton dimension: 512 x 385 x 416 mm
Export gross weight: 16.8 kg
