Meta Quest 2 Elite Strap
Quicklinx: GYP3WS00 Mfr#: 301-00375-01
Upgrade your comfort and secure your headset in the perfect position for the clearest visuals, however much you move.
Enhance your comfort
Straps, bracing and an easily adjustable fit wheel work together for the perfect fit.
Stay in the sweet spot
Keep your headset in the right position for the best visuals, even as you move.
Meta virtual reality headset strap
Virtual reality headset strap
17.5 cm x 21.5 cm x 10.4 cm
179 g
Meta Quest 2 (256 GB), Quest 2 (64 GB)
17.5 cm - 21.5 cm - 10.4 cm
179 g
20.1 cm x 29.4 cm x 12.4 cm
