Play in comfort and get up to two hours additional VR game playtime with this adjustable ergonomic head strap that features a built-in, lithium-ion battery pack. Charge your Meta Quest 3 and head strap battery simultaneously with a single charging cable. The strap easily adjusts to fit most head sizes with the easy-to-use dial while distributing headset weight for a more comfortable fit. This genuine Meta Quest accessory also reduces fatigue with a soft, flexible silicone support that cradles the back of your head and adds stability.
Ready for anything
This compact, lightweight strap reduces facial pressure and evenly distributes weight for a more comfortable fit. It also has improved durability, building on the learnings from our earlier generations of Elite Strap.
Keep the fun going
Get up to two hours additional VR game playtime with the built-in battery pack. Charge your headset and head strap battery simultaneously using a single charging cable.
Adjusts in seconds
A twist of the adjustment dial gives you a snug, precise fit around your head, so you can move confidently whether you're battling it out or getting your sweat on.
Longer immersion
A soft, flexible silicone support cradles the back of your head for the most comfortable and balanced fit for any experience.
Seamless compatibility
Works with the Meta Quest 3 Charging Dock for effortless headset and controller charging. Also fits in the Meta Quest 3 Carrying Case without having to be removed.
Genuine Meta Quest accessory
Built to work seamlessly with Meta Quest 3 and backed by a one year warranty, this official accessory has been tested for quality and durability – ensuring you get the best look, feel, compatibility and performance.
Comfortable
Enhanced stability and ergonomics allow for more comfort. -
Personalized fit
With improved fine tuning for better adjustment. -
Distributed weight
Allows for longer, more comfortable time in MR. -
Extended battery capacity
The built-in rechargeable battery enhances the time for uninterrupted usage. -
Charging indication
LED light indicates charging levels.
- Meta Elite - VR headband for virtual reality headset
- Product Type
- VR headband
- Intended For
- Virtual reality headset
- Battery
- Rechargeable
- Run Time (Up To)
- 2 hour(s)
- Package Content
- Head strap with battery
- Product Material
- Plastic, fabric, silicone
- 17.31 cm x 10.15 cm x 24.1 cm
- 331 g
- White
- Designed For
- Meta Quest 3
- Product Type
- VR headband
- Intended For
- Package Content
- Product Material
- 17.31 cm
- 10.15 cm
- 24.1 cm
- 331 g
- White
- Rechargeable Battery
- Rechargeable
- Capacity
- 2300 mAh
- Run Time (Up To)
- 2 hour(s)
- Designed For
- Meta Quest 3
Meta Quest 3 Elite Strap with Battery
