Go all in with enhanced comfort and battery life. This ergonomic strap increases balance and support with a quick twist of the fit wheel. The built-in battery doubles your playtime, letting you stay focused from the first step to the final mission.
Extend your play time
A built-in battery extends your play time between charges.
Maximise your comfort
A balancing design uses battery weight to lift the headset away from your face for a lighter feel.
Seamless compatibility
Engineered for use with official Meta Quest hardware and accessories (sold separately).
- Meta virtual reality headset strap
- Product Type
- Virtual reality headset strap
- 20 cm x 12 cm x 37 cm
- 179 g
- Designed For
- Meta Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB); Oculus Quest 2, Quest 2 (256 GB)
- Product Type
- 20 cm - 12 cm - 37 cm
- 179 g
- Shipping Dimensions (WxDxH) / Weight
- 29.4 cm x 20.1 cm x 12.4 cm
- Designed For
- Meta Quest 2, Quest 2 (128 GB), Quest 2 (256 GB), Quest 2 (64 GB) , Oculus Quest 2, Quest 2 (256 GB)
