The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability.
Say good-bye to cords and enjoy wireless freedom, so it's easy to use your mouse on the couch with your laptop - or even when you're hooking your laptop up to your TV.
EXTRA-SMALL SHAPE, GOES WHEREVER YOU GO
You can take the Mini Mouse wherever you take your laptop-thanks to its pocket-ready, extra-small design -
RELIABLE WIRELESS CONNECTION
Say good-bye to cords and enjoy the freedom and convenience of wireless -fast data transmission and virtually no delays or dropouts.(up to 10 meters) -
TINY NANO RECEIVER
The nano receiver is so small it stays in your USB port-without worry of losing or breaking it. If you do need to remove it, it stores inside the mouse -
LOGITECH RELIABILITY
You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty -
WORKS ON ALL OPERATING SYSTEMS
Your mouse works with Windows , Mac, Chrome and Linux . No matter what type of computer you own today-or buy tomorrow-you can depend on your mouse to work like you expect
- Logitech M187 - mouse - 2.4 GHz - black
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Black
- 5 cm x 8 cm x 2.5 cm
- 51 g
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Scrolling wheel, Nano wireless receiver
- Battery
- 1 x AAA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Mouse
- Wireless Receiver
- 5 cm
- 8 cm
- 2.5 cm
- 51 g
- Black
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Optical
- 1 x USB - 4 pin USB Type A
- AAA type
- Installed Qty
- 1
- OS Required
- Limited warranty - 3 years
