The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability.
Say good-bye to cords and enjoy wireless freedom, so it's easy to use your mouse on the couch with your laptop - or even when you're hooking your laptop up to your TV.
Extra-small shape
The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability. -
Tiny nano receiver
The nano receiver is so small it stays in your USB port-without worry of losing or breaking it. If you do need to remove it, it stores inside the mouse. You'll enjoy the freedom of wireless with more precision and control than your laptop's touchpad. -
Logitech Advanced 2.4 GHz wireless
Say good-bye to cords and enjoy wireless freedom (up to 10 meters (or 33 feet)), so it's easy to use your mouse on the couch with your laptop-or even when you're hooking your laptop up to your TV. -
Logitech reliability
You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty. -
Goes wherever you go
You can take the Mini Mouse wherever you take your laptop-thanks to its pocket-ready, extra-small design. -
Free yourself
The tiny nano receiver stays in your USB port-and lets you enjoy the freedom of wireless with more precision and control than your laptop's touchpad. -
Confident connection
Enjoy the reliability of a cord with the convenience of wireless-thanks to Logitech Advanced 2.4 GHz wireless technology.
- Logitech M187 - mouse - 2.4 GHz - red
- Mouse
- Connectivity Technology
- Wireless - 2.4 GHz
- Red
- Wireless Receiver
- USB wireless receiver
- Movement Detection Technology
- Optical
- Scrolling wheel, Nano wireless receiver
- Battery
- 1 x AAA type
- OS Required
- Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
- Compatible with Windows 7
- 3 years warranty
- Mouse
- Wireless Receiver
- Red
Input Device
- Wireless
- Interface
- 2.4 GHz
- Max Operating Distance
- Up to 10 m
- Optical
- 1 x USB - 4 pin USB Type A
- AAA type
- Installed Qty
- 1
- OS Required
- Limited warranty - 3 years
