The Mini Mouse is so small it'll easily fit in your purse, handbag or pant pocket for extra-portability.
Say good-bye to cords and enjoy wireless freedom, so it's easy to use your mouse on the couch with your laptop - or even when you're hooking your laptop up to your TV.
EXTRA-SMALL SHAPE, GOES WHEREVER YOU GO
You can take the Mini Mouse wherever you take your laptop-thanks to its pocket-ready, extra-small design -
RELIABLE WIRELESS CONNECTION
Say good-bye to cords and enjoy the freedom and convenience of wireless -fast data transmission and virtually no delays or dropouts.(up to 10 meters) -
TINY NANO RECEIVER
The nano receiver is so small it stays in your USB port-without worry of losing or breaking it. If you do need to remove it, it stores inside the mouse -
LOGITECH RELIABILITY
You get the high quality and reliability that have made Logitech the global leader for mice-plus a three-year limited hardware warranty -
WORKS ON ALL OPERATING SYSTEMS
Your mouse works with Windows , Mac, Chrome and Linux . No matter what type of computer you own today-or buy tomorrow-you can depend on your mouse to work like you expect
 - Logitech M187 - mouse - 2.4 GHz - white
 - Mouse
- Connectivity Technology
 - Wireless - 2.4 GHz
 - White
 - 5 cm x 8 cm x 2.5 cm
 - 51 g
- Wireless Receiver
 - USB wireless receiver
- Movement Detection Technology
 - Optical
 - Scrolling wheel, Nano wireless receiver
- Battery
 - 1 x AAA type
- OS Required
 - Linux Kernel 2.6 or later, Microsoft Windows Vista / XP / 7, Apple MacOS X 10.5 or later
- Microsoft Certification
 - Compatible with Windows 7
 - 3-year warranty
 - Mouse
- Wireless Receiver
 - 5 cm
 - 8 cm
 - 2.5 cm
 - 51 g
 - White
Input Device
 - Wireless
- Interface
 - 2.4 GHz
- Max Operating Distance
 - Up to 10 m
 - Optical
 - 1 x USB - 4 pin USB Type A
 - AAA type
- Installed Qty
 - 1
- OS Required
 - Limited warranty - 3 years
