Logitech K230 Wireless Keyboard
Quicklinx: 7WRGWS00 Mfr#: 920-003338
This clever little keyboard has all the standard keys - so you can save lots of space without missing a thing. The reliable wireless connection lets you work or play up to 10 meters away with virtually no delays or dropouts.
  • Much smaller design, same keys
    The compact keyboard is about 36% smaller than our standard keyboards but still has all the standard keys-so doing the things you love is as easy as ever
  • Advanced 2.4 GHz wireless
    So you can work or play in more places-like your comfy couch-the wireless connection virtually eliminates delays, dropouts and interference and gives you range of up to 10 meters (33 feet)
  • Connect with ease
    You pop the tiny Logitech Unifying receiver in your notebook and leave it there. You can even add more devices. Plug it. Forget it. Add to it
  • 128-bit AES encryption
    It helps protect your information by encrypting data transfer between the keyboard and receiver with one of the highest levels of data encryption available
  • 2-year battery life
    With the extended battery life and auto-sleep, you can write Facebook updates, emails and Yelp reviews for years without the hassle of changing batteries
  • Sleek, customizable design
    The battery door on top of the keyboard doubles as a fun design element with light gray, pink and blue options you can swap in to suit your mood or décor
  • Plug-and-play simplicity
    Setup couldn't be easier-you simply plug the wireless receiver into a USB port on your computer and start tweeting , blogging and IMing right away without software
  • Whisper-quiet keys
    The keys barely make a sound, so you can hear the song you're listening to and not what you're typing
  • Super space saver
    This clever little keyboard has all the standard keys-so you can save lots of space without missing a thing
  • Free to roam
    The reliable wireless connection lets you work or play up to 10-meters (33 feet) away with virtually no delays or dropouts
  • Power up for years (2-year battery life)
    With a 2-year battery life and auto-sleep, you can catch up on Facebook, email friends and tweet on Twitter for years without the hassle of changing batteries
Logitech Wireless Keyboard K230 - keyboard - UK
Keyboard
2.4 GHz
Wireless Receiver
USB wireless receiver
Wireless
Localization and Layout
Hot Keys Function
Volume, mute
38 cm x 11.2 cm x 1.8 cm
320 g
Microsoft Certification
Compatible with Windows 7
3-year warranty
Keyboard
2.4 GHz
Max Operating Distance
Up to 10 m
Wireless Receiver
Input Device
Wireless
Hot Keys Function
Volume, mute
Keyboard Technology
Membrane
38 cm
11.2 cm
1.8 cm
320 g
3 battery doors
Plug and Play, AES-128
Microsoft Windows Vista / XP / 7
AAA type
Installed Qty
2
Limited warranty - 3 years
