Logitech MX Vertical Advanced Ergonomic Mouse
Quicklinx: FDBFWS00 Mfr#: 910-005448
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless, Wired
Colour: Graphite
Compatibility: PC
19 In Stock
£88.53 ex VAT
£106.23 inc VAT
Ergonomics meets performance in MX Vertical, an advanced ergonomic mouse designed to reduce muscle strain and improve posture.
  • Less fatigue, better performance
    MX Vertical's natural handshake position reduces muscular activity by 10 percent compared to a standard mouse - without any loss in overall performance.
  • 57° vertical angle for improved wrist posture
    MX Vertical's unique 57° vertical angle reduces the pressure on your wrist, while your thumb is positioned comfortably on the thumb rest.
  • User-tested, ergonomist-approved
    MX Vertical has been designed and tested with criteria set out by leading ergonomists - improve posture, lower muscle strain, and reduce wrist pressure.
  • Advanced optical tracking with cursor speed switch
    The 4000 DPI high-precision sensor results in 4x less hand movement and reduces fatigue. The cursor speed switch instantly adjusts DPI speed and accuracy with the touch of a button.
Logitech MX Vertical - vertical mouse - USB, Bluetooth, 2.4 GHz - graphite
Vertical mouse - ergonomic
Wireless, wired - USB, Bluetooth, 2.4 GHz
Graphite
7.9 cm x 12 cm x 7.85 cm
135 g
Wireless Receiver
USB wireless receiver
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
4000 dpi
Performance
Realtime sensitivity switching 400 - 4000 dpi
Logitech Unifying receiver, on-the-fly DPI switching, Logitech Advanced Optical Tracking, Easy-Switch technology, precision scroll wheel, Logitech Flow
Microsoft Windows 7 / Windows 8 or later, Apple macOS 10.12 or later, Apple MacOS X 10.12 or later
Vertical mouse
Wireless Receiver
Ergonomic Design
7.9 cm
12 cm
7.85 cm
135 g
Graphite
Input Device
Wireless, wired
Max Operating Distance
Up to 10 m
Optical
Buttons Qty
6
Movement Resolution
4000 dpi
Performance
USB-C charging cable
Lithium polymer
240 mAh
Standby Time
Up to 4 month
Shipping Width
8.61 cm
Shipping Depth
15.2 cm
Shipping Height
19.4 cm
Shipping Weight
372 g
Type: Mouse
Wired / Wireless: Wired
Colour: Graphite
Compatibility: PC
Brand: Logitech
