Logitech M171 Mouse Wireless 2.4 GHz USB Wireless Reciever Black
Quicklinx: CHRVWS00 Mfr#: 910-004424
Recommended Use: Leisure
Type: Mouse
Wired / Wireless: Wireless
Colour: Black
Compatibility: PC
£11.08 ex VAT
£13.29 inc VAT
This mouse ensures a strong and consistent wireless connection. With virtually no delays or dropouts, you'll work and play with confidence. Work for several months between battery changes thanks to the mouse's long-lasting battery.
  • ANY HAND, ANYWHERE
    The compact, wireless M171 has a fully ambidextrous design that easily fits within your laptop bag, so you can get to work anywhere-whether you're left- or right-handed
  • PLUG & PLAY WIRELESS
    Up to 10 meters Wireless range may vary based on user, environmental and computing conditions of wireless freedom with a strong, reliable USB receiver. That means no delays, no dropouts. M171 is compatible with Windows, macOS, Chrome OS and Linux and works instantly when you plug the USB receiver into your computer or laptop
  • Easy Navigation, Smooth Control
    Easy navigation thanks to a controlled line-by-line scrolling and optical tracking. The optical sensor gives you smooth and accurate cursor control on almost any surface. That means accurate mouse movements with no more annoying missed clicks
  • QUALITY YOU CAN RELY ON
    The mouse is built with the same high quality standards that have made Logitech the global leader for mice and keyboards Based on independent sales data (in units) aggregated for Logitech mice and keyboards from major global markets including Canada, China, France, Germany, Indonesia, Republic of Korea, Russian Federation, Sweden, Taiwan, Turkey, UK, US (July '19 - July '20 period). Retail channel only. . Durable and reliable, M171 also works up to 12 months Battery life may vary based on use and computing conditions. without changing batteries thanks to the on/off switch button and auto-sleep power-saving mode
  • BETTER THAN A TOUCHPAD
    Using a mouse is more ergonomic than a touchpad Logitech Ergonomic Lab study on 23 participants in (Oct / 2019) with two Logitech standard mice and two standard, embedded trackpads . The compact shape and wireless capability lets you work comfortably -at home, the office, or anywhere in between
  • Decades of Design Excellence
    We bring over 25 years of expertise and innovation creating mice of various sizes and shapes that provide an extra degree of comfort. Our solutions are meticulously crafted to fit right- or left-handed users, making it easier to find the product that's right for you
  • 1
    RECYCLED PLASTICS The plastic parts in M171 include certified post consumer recycled plastic - minimum 59% for Blue/Black, Red/Black, Black/Grey, Grey/Black, Off-white and 38% for Rose and Blue gray Excludes receiver and printed wiring assembly (PWA) plastics, and packaging. - to give a second life to end-of-life plastic from old consumer electronics and help reduce our carbon footprint
  • 2
    CARBON CLARITY We believe everyone should know what they're consuming. The carbon footprint of this product is 4.05 kg CO 2 e . We're working hard to reduce it, and we have offset our residual carbon impact to zero by supporting forestry, renewables and climate-impacted communities
Logitech M171 - mouse - 2.4 GHz - black
Mouse
Wireless - 2.4 GHz
Orientation
Right and left-handed
6.15 cm x 9.77 cm x 3.52 cm
70.5 g
Wireless Receiver
USB wireless receiver
AA type
Apple MacOS X 10.8 or later, Google Chrome OS, Linux Kernel 2.6 or later, Microsoft Windows 7 / 8 / 10 or later
Mouse
Wireless Receiver
Orientation
6.15 cm
9.77 cm
3.52 cm
70.5 g
Input Device
Wireless
2.4 GHz
Max Operating Distance
Up to 10 m
AA type
Run Time (Up To)
12 months
Type: Mouse
Colour: Black
Compatibility: PC
Brand: Logitech
