Logitech Harmony Smart Control
Quicklinx: BGX4WS00 Mfr#: 915-000196
Control your home theater devices from the iPhone or Android mobile phone you already own. Anyone in the house can download the Harmony iPhone or Android app turns their mobile phone into a personal universal remote control, including 50 favorite channel icons and gesture control.
Consolidate 8 remote controls into one simple mobile app. Harmony is compatible with over 225,000 home theater devices. And unique to Harmony is Logitech's patented Smart State technology, which remembers your devices' power and input settings and automatically adjusts them based on what you want to do.
  • Your smartphone is now a remote control
  • Swipe and tap control
    Swipe or tap your thumb across your smartphone screen to adjust the volume, change the channel, fast-forward, rewind, pause, play and skip forward or back.
  • A smartphone app that simply works
Logitech Harmony Smart Control universal remote control
Universal remote control
Infrared
Supported Device Qty
8
Supported Devices
AV System, Game console, TV
Wireless Technology
IEEE 802.11b/g/n, Bluetooth
Remote control unit battery
Infrared
Wireless Technology
8
Supported Devices
Operating System
MS Windows XP, MS Windows 7, MS Windows Vista, Apple MacOS X 10.4.8 or later, Windows 8, Android 2.3 or later, iOS 5.0 or later
1 x USB cable - external
AC power adaptor, USB cable, IR receiver, Harmony Hub
BGX4 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
BGX4 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.71
BGX4 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
