Linksys Wireless-N Broadband Router With Storage Link (Powered By Linux)
Quicklinx: 628DWS00 Mfr#: WRT160NL-UK
  • IEEE 802.11n (draft)
Enjoy fast wireless connectivity for your home or home office. The Linux-based Wireless-N Broadband Router with Storage Link is designed to deliver plenty of speed and coverage, so multiple users can go online, transfer large files, print, and stream stored media - all at once, all without wires.
The speed and bandwidth of Wireless-N, today's most advanced wireless technology, makes it easy for multiple users to share Internet access, files and printing. Enjoy media-intensive activities like gaming, video and Voice-over-IP phone calls - all at once, with less lag and performance degradation. Achieves faster speeds when used with Wireless-N enabled devices, but is fully compatible with Wireless-G and -B equipment.
  • Do more, faster
  • Wireless-N power
  • Reliable coverage
    Experience coverage you can count on, all around your home. Wireless-N's multiple in, multiple out MIMO technology actually uses the signal reflections that confuse ordinary wireless technologies to boost range and reduce dead spots.
  • Storage for all
    The Storage Link feature lets you connect a hard drive or flash-based USB storage device directly to your network to easily add gigabytes of storage. Access your music, video, or data files from anywhere within your network. Built-in DLNA 1.5 compatible media server streams to PCs or UPnP AV digital media adapters.
  • Connect to more
    Four 10/100 Ethernet ports let you connect printers, networked storage drives, and other Ethernet-enabled devices to your network, so you can access and share them from all around the house.
Linksys WRT160NL - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
Routing Protocol
RIP, static IP routing
Remote Management Protocol
HTTP, HTTPS
Full duplex capability, firewall protection, DMZ port, DHCP support, NAT support, MDI/MDI-X switch, SPI, MAC address filtering, VPN passthrough, 256-bit encryption, Access Point operational mode, firmware upgradable, MIMO technology, WPS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft)
20.3 cm x 15.9 cm x 3.3 cm
283 g
Microsoft Certification
Compatible with Windows 7
Apple MacOS X 10.4.x or later, Microsoft Windows Vista / XP
United Kingdom
Enclosure Type
Desktop
Wireless, wired
Routing Protocol
HTTP, HTTPS
Encryption Algorithm
128-bit WEP, WPA, WPA2
Authentication Method
RADIUS
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft), UL, cUL, RSS-210, IC, FCC
Status Indicators
Port status, power, link OK, link/activity
WAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
2
Gain Level
1.8 dBi
External power adapter
1 x network cable , 1 x USB extension cable
United Kingdom
Software Included
Drivers & Utilities
20.3 cm
15.9 cm
3.3 cm
283 g
10 - 80%
