Linksys LCAM0336OD-UK SMB grade Indoor 360 3M PoE Camera
Quicklinx: 9DYGWS00 Mfr#: LCAM0336OD-UK
Protect your business and enhance your situational awareness with the all-purpose Linksys 1080p 3-magepixel indoor/outdoor 360 mini-dome camera. Inside or outside your business, Linksys network cameras provide superior security, surveillance, and supervision.
Linksys 1080p 3MP Indoor/Outdoor 360 Mini-Dome Camera - network surveillance camera
Network surveillance camera - fixed - outdoor, indoor - vandal / waterproof
Audio
Yes: built-in microphone
400 g
Wired
Camera
Max Resolution
2048 x 1536
Optical Sensor Type
CMOS 3 MP
Minimum Illumination
0.1 lux - B&W - F2.0 , 0.5 lux - colour - F2.0
Focal Length
0.98 mm - 1.02 mm
Ethernet 10Base-T
Voltage
PoE
Motion sensor, Wide Dynamic Range (WDR), SD/SDHC-card slot
Environmental Parameters (operating)
-40 °C - 50 °C; 10 - 80% (non-condensing) relative humidity
Audio Support
Wired
400 g
United Kingdom
Camera
Colour - fixed - outdoor, indoor - vandal / waterproof
Digital Video Format
MPEG-4, MJPEG, H.264
Max Digital Video Resolution
2048 x 1536
Video Capture
2048 x 1536 @ 20 fps , 1920 x 1080 @ 30 fps , 1280 x 720 @ 30 fps
Image Sensor
3 MP CMOS
Effective Pixels
2048 x 1536
Lens Construction
Focal Length
0.98 mm - 1.02 mm
Horizontal Field of View (degree)
182
Vertical Field of View (degree)
182
Network Interface
Ethernet 10Base-T
1 x network - Ethernet 10Base-T - RJ-45
FCC, IC Class A, IP67, IK10
Power Requirements
PoE
-40 °C
50 °C
Relative Humidity (operating)
9DYG C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.91
