Bosch Indoor 360 Camera
Quicklinx: GY93WS00 Mfr#: 8750000983
  • microSD Card
The 360° Indoor Camera lets you keep an eye on every nook and cranny in the room, at any time. It live streams in HD video.
Keep an eye on every corner of a room at any time with the intelligent Indoor Camera from Bosch Smart Home. It provides outstanding 1080p, high-quality images around the clock, whenever you want and only when you want.
360° all-around viewing
Thanks to 360 degree all-around viewing the smart Indoor Camera keeps the entire room under surveillance. The rotating camera head follows movements and the camera notifies you on your smartphone with video clips of any incidents.
Guaranteed privacy
When you want privacy it is guaranteed absolutely. At the tap of a finger on the Indoor Camera or a click on your smartphone app the camera lens retracts fully into the housing.
No follow-up costs
The indoor wifi camera stores 200 clips in a cloud for 30 days free of charge. 25 favourites can be stored for as long as you like with each video able to attach to an email for external sharing.
Razor-sharp images – even at night
The 360 degree camera supplies razor-sharp full 1080p HD images and videos with a zoom function – even at night thanks to infrared lighting. So you can spot burglars even in complete darkness.
Obeys Alexa
"Alexa, switch on the living room camera" – Control selected functions of your wireless Indoor camera and the Bosch Smart Home System using your voice with Alexa. An overview of other functions and Amazon Alexa devices that are compatible with Bosch Smart Home is available on our Amazon Alexa partner website and in our FAQs.
Easy installation
Install the 360 degree camera in a few minutes. Simply use the Bosch Smart Camera app, which guides you step-by-step through 360° Indoor Camera integration. However, if you wish for further support, simply watch our installation video with step-by-step instructions.
Box contents
  • 1 360° Indoor Camera
  • 1 Mains plug (adapter EU, UK, US)
  • 1 Installation guide
  • Intelligent home monitoring
    The 360° Indoor Camera allows you to make sure all is well at home even when you're away. Whether you are making sure the kids are doing their homework, shouting to get the dog off the sofa or simply checking in, the 360° Indoor Camera provides HD video so you don't miss a thing.
  • Doubly secure
    The Bosch Smart Home 360° Indoor Camera gives you the peace of mind security that you are looking for. It is entirely up to you to decide when and what the camera is allowed to record, just tap the head on the camera to activate privacy mode.
Bosch Smart Home 360° Indoor Camera - network surveillance camera
Network surveillance camera - fixed - indoor
Audio
Yes: built-in speaker, two-way audio capability, built-in microphone
5 cm x 5 cm x 18.2 cm
450 g
Wireless
Camera
Video Modes
1080p
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Voltage
DC 5 V
120° field of view, 79° field of view (vertical)
Environmental Parameters (operating)
0 °C - 40 °C
Audio Support
Wireless
5 cm
5 cm
18.2 cm
450 g
Camera
Colour - fixed - indoor
Video Modes
1080p
Network Interface
Supported Memory Cards
microSD Card, microSDXC Card
Power Requirements
DC 5 V
6 Watt
Shipping Width
19 cm
Shipping Depth
10 cm
Shipping Height
28.5 cm
