E900 Wireless-N300 Router is built with leading 802.11n technology, create a powerful home wireless network in minutes. Connect your computers, Internet-ready TVs, game consoles, smartphones, and other Wi-Fi devices at fast transfer rates for an unrivaled experience.
Keep Wi-Fi freeloaders and Internet threats at bay with WPA2 encryption and SPI firewall to help keep your network protected.
Ideal for:
Surfing the web and emailing
Networking smaller homes or apartments
Connecting devices
Key features*:
High speed (up to 300 Mbps) for fast wireless transfer rates
Reliable range with MIMO antenna technology
Four Ethernet ports to connect wired devices to the network
Wireless-N technology
Built with leading 802.11n technology, create a powerful home wireless network in minutes. Connect your computers, Internet-ready TVs, game consoles, smartphones, and other Wi-Fi devices at fast transfer rates for an unrivaled experience. -
Advanced security
Keep Wi-Fi freeloaders and Internet threats at bay with WPA2 encryption and SPI firewall to help keep your network protected. -
Benefits of Fast Ethernet
Use the four Fast Ethernet (10/100) ports for quick file sharing between computers and servers. -
Home network ready
Connect computers, printers, and more to your wireless network and the Internet. QoS traffic prioritization technology delivers maximum speed and performance so you can enjoy fast downloads and reliable gaming. -
IPv6 enabled
It supports the latest Internet protocol technology to future-proof your network.
- Linksys E900 - wireless router - 802.11b/g/n - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 300 Mbps
- Routing Protocol
- RIP, static IP routing
- 128-bit encryption, NAT support, Stateful Packet Inspection (SPI), dynamic DNS server, MAC address filtering, IPv6 support, VPN passthrough, firmware upgradable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding, IPv4 support
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 18.9 cm x 15.2 cm x 3.1 cm
- 202 g
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 300 Mbps
- Routing Protocol
- Encryption Algorithm
- 128-bit WEP, WPA, WPA2
- IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, UL, cUL, ICES-003, RSS-210, FCC
- Status Indicators
- Power, link/activity
- LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 2
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- 18.9 cm
- 15.2 cm
- 3.1 cm
- 202 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 80% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.25 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £12.00 |
