The Linksys E2000 offers Wireless-N technology and extended range to provide wireless coverage throughout your home. Selectable dual-band (2.4 GHz or 5 GHz) technology helps avoid network interference, enabling smoother file transfers and media streaming. Four Gigabit Ethernet ports allow for faster file transfers with other Gigabit devices. Plus, included Cisco Connect software gets you set up in a few simple steps and offers powerful tools for managing your wireless network. Easily customize your security settings, set Parental Controls, and access advanced settings.
Quick to install
Cisco Connect software has three simple steps to get you set up and your secure wireless network is ready to go. A streamlined user interface allows you to choose from simple to advanced settings with no hassle. -
Benefits of Gigabit
Use the Gigabit Ethernet ports for quicker file sharing between other Gigabit-enabled devices like media servers, hard drives and computers. -
Speed up your wireless network with a router that connects your computer, game consoles and other Wi-Fi devices at high transfer speed.
- Linksys E2000 - wireless router - 802.11a/b/g/n - desktop
- Wireless router - 4-port switch (integrated)
- Enclosure Type
- Desktop
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz / 5 GHz
- Data Transfer Rate
- 300 Mbps
- PPTP, L2TP, PPPoE
- Routing Protocol
- RIP, static IP routing
- Remote Management Protocol
- HTTP, HTTPS
- 128-bit encryption, NAT support, Stateful Packet Inspection (SPI), MAC address filtering, VPN passthrough, parental control, firmware upgradable, wall mountable, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), DHCP server, port forwarding
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP
- 20.2 cm x 16 cm x 3.4 cm
- 300 g
- Microsoft Certification
- Compatible with Windows 7
- System Requirements
- Microsoft Windows 7, Microsoft Windows Vista SP1, Microsoft Windows XP SP3, Apple MacOS X 10.4.11 - 10.6.1
- Localisation
- United Kingdom
- 1-year warranty
- Enclosure Type
- Desktop
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz / 5 GHz
- 300 Mbps
- PPTP, L2TP, PPPoE
- Routing Protocol
- HTTP, HTTPS
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 40-bit WEP, WPA, WPA2
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n, UPnP, IC CS-03, FCC
- Status Indicators
- Port status, power
- LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x RJ-45
Aerial
- Aerial
- Internal
- Antenna Qty
- 3
- Power Device
- External power adapter
- Cables Included
- 1 x network cable
- Localisation
- United Kingdom
- Software Included
- Drivers & Utilities
- OS Required
- 20.2 cm
- 16 cm
- 3.4 cm
- 300 g
- Limited warranty - 1 year
- 0 °C
- 40 °C
- 10 - 85%
