Linksys Dual-Band Wireless-N BT ADSL2+ Modem Router with Gbt
Quicklinx: 6BG9WS00 Mfr#: WAG320N-UK
  • IEEE 802.11n (draft 2.0)
Enjoy fast wireless connectivity for your home or office. The Dual-Band Wireless-N ADSL2+ Modem Gigabit Router has a built in high speed ADSL2+ Modem for a fast, "Always On" connection to the Internet. Wireless connections are radio band selectable to avoid interference in your area, and the four built in Gigabit ports supply high speed connections to your wired devices.
LAN 4-port Gigabit switch
Wi-Fi works in either the 2.4 or 5 gigahertz radio bands to help avoid interference
Wireless-N technology for robust range and speed and more complete coverage throughout your home
Wi-Fi Protected Setup helps make wireless configuration secure and push button easy
Advanced wireless security and a powerful firewall help protect you from Internet hackers
  • Power of N
    Connect everybody in your home at once without wires. Dual Wireless-N radio bands let you choose the one with the least interference in your area. Either one delivers high performance for smooth streaming video, high frame-rate gaming, fast data transfers, and heavy Internet use from multiple users - all with great range and reduced dead spots. It also connects to your existing Wireless-G, -B, or -A devices.
  • Reliable coverage
    Experience coverage you can count on, all around your home. Wireless-N's Multiple in, Multiple Out MIMO technology actually uses the signal reflections that confuse ordinary wireless technologies to boost range and reduce dead spots.
  • Connect faster
    Access more over your network. Connect Gigabit-enabled networked storage drives, computers, printers, and other devices to the four 10/100/1000 Gigabit Ethernet ports and break the bottlenecks other routers suffer.
  • Advanced security
    Advanced wireless security and SPI firewall protection designed to help safeguard your home network and computers from most Internet attacks.
Linksys WAG320N - wireless router - DSL modem - Wi-Fi - desktop
Wireless router - DSL modem - 4-port switch (integrated)
Enclosure Type
Desktop
Digital Signaling Protocol
ADSL, ADSL2, ADSL2+
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
SPI, MAC address filtering, wall mountable
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0)
20.2 cm x 16 cm x 3.4 cm
362 g
Microsoft Certification
Compatible with Windows 7
Apple MacOS X 10.4 or later, Microsoft Windows Vista / XP
United Kingdom
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
Wireless, wired
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA, WPA2
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, IEEE 802.11n (draft 2.0), FCC, A-Tick
Status Indicators
Port status, power, link/activity
Line Properties
Line Coding Format
CCK, 64 QAM, BPSK, QPSK, 16 QAM, OFDM
Framing Format
ANSI T1.413
Communications
DSL modem
ADSL, ADSL2, ADSL2+
Protocols & Specifications
ITU G.992.1 (G.DMT), ITU G.992.2 (G.Lite), ITU G.992.3 Annex A, ITU G.992.5 Annex A
WAN: 1 x ADSL2+ - RJ-11 , LAN: 4 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x
Aerial
Aerial
Internal
Antenna Qty
3
External power adapter
1 x network cable
United Kingdom
Software Included
Drivers & Utilities
Additional Requirements
CD-ROM
20.2 cm
16 cm
3.4 cm
362 g
10 - 85%
Resources
The following resources are available for the Linksys Dual-Band Wireless-N BT ADSL2+ Modem Router with Gbt
