LightwaveRF 4 Gang Smart Dimmer - Stainless Steel
Quicklinx: DX3VWS00 Mfr#: L24
Begin your home automation adventure by using our stylish smart dimmer to control your lights.
Smart Series products incorporate Apple HomeKit compatibility, 2-way communication, soft start dimmers and more! The dimmers are quick and easy to DIY install and do not require extra cabling. An optional 10mm spacer is also included.
HomeKit Control
Lightwave’s remote control dimmer switch seamlessly integrates with Apple HomeKit, so you can control your home and make optimal use of smart lighting from your iPhone or iPad, from wherever you are.
Smart Series device
Requires Link Plus and Link Plus App for operation
Compatibility
Works with Apple HomeKit, Amazon Alexa, Google Assistant and IFTTT
DIY retrofit
All Lightwave devices are safe and legal to DIY retrofit in your own home
  • Easy compatibility
    A contemporary stainless steel finish houses a smart dimmer to ensure compatibility with the majority of current dimmable LED lamps.
  • Feature-rich
    The Smart Series dimmer light switch offers soft-start illumination, 2-way switching as default and multi-way wireless communication with other Lightwave dimmers.
  • Simple installation
    Standard wiring configurations make the smart light dimmer switch easy to DIY install or via a suitably qualified electrician. A 10mm spacer is included for shallower back boxes.
LightwaveRF L24 - dimmer - stainless steel
Dimmer
Power Source
Hardwired
Internet of Things (IoT) Platform
Apple HomeKit
Intelligent Assistant
Google Assistant, Alexa
Wireless
Frequency Band
868 MHz
Stainless steel
15 cm x 2.8 cm x 8.8 cm
Dimmer
Power Source
Hardwired
Wireless
Frequency Band
868 MHz
4-gang, LED indicators, up to 200 Watt per gang, compatible with incandescent light bulbs (up to 200W), compatible with halogen light bulbs (up to 200W)
Platform
Apple HomeKit
Compatible Services
IFTTT
2 mounting screws, spacer
Stainless steel
Nominal Voltage
AC 230V
Warranty
RoHS, EN 62479:2010, IEC 62321-1:2013, EN 300 220-1 V3.1.1, EN 300 220-2 V3.1.1, EN 301 489-1 V2.2.0, EN 60669-2-5:2013
15 cm
2.8 cm
8.8 cm
