Liebert PSI XR 3000VA 2700W 230V RACK/TOWER UPS
Quicklinx: 7GX5WS00 Mfr#: PS3000RT3-230XR
Liebert PSI-XR 3000VA is a compact, line-interactive UPS system designed especially for IT applications such as network closets and small data centers. The flexible design of Liebert PSI-XR allows the unit to be configured as a self-standing tower or to be rack-mounted within a 2U space. It is available in four capacities.
Liebert PSI-XR PS3000RT3-230XR - UPS - 2700 Watt - 3000 VA
UPS - rack-mountable / external
Rack Size
2U
46 kg
Output Voltage
AC 220/230/240 V ± 5%
Power Capacity
2700 Watt / 3000 VA
Input Connectors
1 x power IEC 60320 C20
Output connectors
6 x power IEC 60320 C13 , 1 x power IEC 60320 C19
Lead Acid
Run Time (Up To)
5 min at full load
USB, serial
Tower stand
Microsoft Windows 2000 / NT, Microsoft Windows Vista / XP
44 cm x 70.05 cm x 8.8 cm
Height (Rack Units)
2U
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage Range
AC 165 - 300 V
Frequency Required
45 - 65 Hz
Input Connectors
Output Voltage
Power Capacity
2700 Watt / 3000 VA
Dataline Surge Protection
Network/phone line - RJ-45/RJ-11
Output Waveform
Sinewave
Surge Suppression
Surge Energy Rating
660 Joules
Circuit Protection
Circuit breaker
Efficiency
96%
Power Factor (PF)
0.9
Lead Acid
Run Time (Up To)
5 min at full load , 13 min at half load
Recharge Time
5 hours
Transfer Time
4 ms
Maintenance free, sealed
Remote Management Interface
USB, serial
1 x management (USB) - 4 pin USB Type B , 1 x management (RS-232) - 9 pin D-Sub (DB-9)
Expansion Slots
1 (total) / 1 (free) x Liebert IntelliSlot
Tower stand
4 x power cable - external , Serial cable - external , USB cable - external
Rack Mounting Kit
Included
Overload protection
IEC 62040-1-1, EN 62040-2, ISTA
Software Included
Drivers & Utilities
0 - 90%
Sound Emission
40 dBA
44 cm
70.05 cm
8.8 cm
46 kg
Shipping Width
56 cm
Shipping Depth
82.1 cm
Shipping Height
22.8 cm
Shipping Weight
51 kg
