Liebert PowerSure PSA 500VA UPS System - 230V
Quicklinx: 7GXQWS00 Mfr#: PSA500MT3-230U
Liebert PSA 500VA is a compact line-interactive UPS that offers cost-effective, full featured power protection for small office computer and electronic equipment. Liebert PSA mixes unique features and extraordinary performance. Designed with simple controls for easy operation, it provides up to five minutes of back-up time at full load: more than enough time to save work in process and shut down your system.
  • Reliable power protection
    The Liebert PSA 500MT UPS offers dependable line interactive UPS technology, ensuring a steady power supply and protection against surges, making it an ideal solution for safeguarding your PC.
  • Efficient energy use
    With a power capacity of 500 VA and a frequency provided of 50/60 Hz, this UPS optimizes power usage, ensuring your devices run efficiently without wasting energy.
  • Adaptable to your environment
    Designed to operate within a wide range of temperatures, from 0°C to 40°C, the Liebert PSA 500MT can adapt to various working environments, ensuring continuous protection.
  • Seamless connectivity
    Featuring an external form factor with one input connector, the UPS integrates smoothly into your existing setup, providing reliable power without the hassle.
  • Advanced battery technology
    Equipped with lead acid battery technology, the Liebert PSA 500MT ensures long-lasting performance and reliability, keeping your devices powered during outages.
Liebert PSA 500MT - UPS - 300 watt - 500 VA
UPS - external
6.4 kg
Load Rating
Individual PC
Input Voltage
AC 230 V
Output Voltage
AC 230 V
Power Capacity
300 watt / 500 VA
Input Connectors
1 x power NEMA 5-15
Output connectors
1 x power NEMA 5-15 (surge) , 3 x power NEMA 5-15
Lead Acid
Batteries Qty
1
USB
9.5 cm x 35.6 cm x 17.1 cm
UPS - external
Load Rating
Individual PC
UPS Technology
Line interactive
Supported Battery Technology
Lead Acid
Input Voltage
AC 230 V
Frequency Provided
50/60 Hz
Frequency Required
50/60 Hz
Input Connectors
1 x power NEMA 5-15
Output Voltage
AC 230 V 50/60 Hz
Power Capacity
300 watt / 500 VA
Dataline Surge Protection
Network - RJ-45
Output Waveform
Stepped approximation to a sinewave
Surge Suppression
Surge Energy Rating
570 joules
Circuit Protection
Circuit breaker
Quantity
1
Lead Acid
Remote Management Interface
USB
1 x management (USB)
Power cable - external - 1.8 m , USB cable - external
Audible alarm, LED indicators, over current protection
cUL, UL 1778, FCC Part 15 B
Limited warranty - parts and labour - 2 years
0 - 90%
9.5 cm
35.6 cm
17.1 cm
6.4 kg
