The multifunction Lexmark MC2535adwe builds on the color output of up to 35 pages per minute with a 4.3-inch (10.9-cm) color touch screen.
4-year guarantee upon registration
For an added level of peace of mind, you can benefit from 4-year guarantee coverage upon registration. -
Engineered to perform - and last
Driven by a 1.2GHz quad-core processor and up to 6 GB of memory, the MC2535adwe prints up to 33 pages per minute and can scan up to 47 images per minute. With its steel frame, long-life imaging system, ease of upgrades and robust paper feeding system, it's ready for lasting performance in any environment. -
Interact with ease
A 4.3-inch e-Task colour touch screen offers a precise, responsive, tablet-like user interface with multi-touch capabilities. The e-Task interface also opens a world of convenience and productivity apps. And the new front-panel power button and direct-print USB port, plus secure browser-based device management, make it even easier to get things done. -
Colour that only looks expensive
Thanks to PANTONE calibration, embedded colour sample pages and Lexmark colour Replacement, you'll get accurate, professional colour in-house. And you'll save toner with included tools that let you choose when and how much colour to print, including mono-only print drivers, user-based colour print permissions and quotas, global colour density control, object-specific colour Saver, proof before printing and more. -
Classic connections, wireless convenience
Beyond included USB and gigabit ethernet, this device lets you connect wirelessly via built-in Wi-Fi, as well as AirPrint, Google Cloud Print, and Mopria on any network with existing Wi-Fi access. And with Lexmark Mobile Print, printing's as easy as hitting print, choosing your printer and picking up your job. -
Energy efficiency
Make every watt count with energy management features that reduce power consumption whether the device is active or in sleep mode. Lower fusing temperature, automatic management of processor cores based on workload, and standard two-sided printing all help it achieve EPEAT Silver rating and ENERGY STAR (2.0) certification. That benefits the planet and your budget. -
Full-spectrum security
Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help keep your information safe - in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honoured Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
- Lexmark MC2535adwe - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 85000 pages
- Recommended Monthly Volume
- 1500 - 8500 pages
- Max Copying Speed
- Up to 33 ppm (mono) / up to 33 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Resolution Class
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 1200 x 600 dpi (600 x 600 dpi color)
- Display
- 4.3"
- Original Size
- 215.9 x 355.6 mm (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, card stock
- Standard Media Capacity
- 250 sheets
- Max Media Capacity
- 1450 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
- AirPrint Enabled
- 44.2 cm x 58.8 cm x 46.2 cm
- 27.1 kg
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 4-year warranty with product registration
- Printer Fonts
- Bitmapped PCL x 2 , Scalable PostScript x 158 , Scalable PCL x 84 , Bitmapped PPDS x 5 , Scalable PPDS x 39
- Fax Type
- Plain paper
- Laser - colour
- 85000 pages
- 1500 - 8500 pages
- Display Diagonal Size
- 4.3"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
- Max Supported Memory
- 6 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PPDS, PDF 1.7, XPS
- Image Enhancement Technology
- 4800CQ
- First Print Out Time B/W
- 8.5 sec
- First Print Out Time Colour
- 8.5 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Document & Media Handling
- Max Original Size
- 215.9 x 355.6 mm
- Original Type
- Sheets
- 50 sheets
- Min Media Weight
- 90.3 g/m²
- Max Media Weight
- 200 g/m²
- Max Media Weight (lb)
- 122 lbs
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm)
- 250 sheets
- 1450 sheets
- 1 sheet
- 150 sheets
- Input tray - 250 sheets , Bypass tray - 1 sheet , Output tray - 150 sheets , RADF - 50 sheets
- Speed Details
- Printing: up to 33 ppm (A4) - B/W (ISO/IEC 24734) , Printing: up to 33 ppm (A4) - colour (ISO/IEC 24734) , Printing: up to 16 spm (A4) - B/W duplex , Printing: up to 16 spm (A4) - colour duplex , Copying: up to 33 ppm (A4) - B/W (ISO/IEC 24735) , Copying: up to 33 ppm (A4) - colour (ISO/IEC 24735) , Copying: up to 16 ppm (A4) - B/W duplex , Copying: up to 16 ppm (A4) - colour duplex , Scanning: up to 47 spm (A4) - B/W , Scanning: up to 50 spm (Letter A) - B/W , Scanning: up to 30 spm (A4) - colour , Scanning: up to 32 spm (Letter A) - colour , Scanning: up to 21 spm (A4) - B/W duplex , Scanning: up to 23 spm (Letter A) - B/W duplex , Scanning: up to 13 spm (A4) - colour duplex , Scanning: up to 14 spm (A4) - colour duplex
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 host - 4 pin USB Type A
- SSL, LEAP, TLS, ARP, TTLS, PEAP, MD5, MS-CHAPv2, SNMP 3
- Operating System Support
- SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, SunSoft Solaris x86 10, IBM AIX 6.1, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Red Hat Enterprise Linux WS 6.0, IBM AIX 7.1, Apple Mac OS X 10.8, SunSoft Solaris x86 11, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Debian Linux 7.0, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10, Apple Mac OS X 10.11, openSUSE 13.2, Debian Linux 8.0, SuSE Linux Enterprise Server 12, Red Hat Enterprise Linux WS 7.0, macOS 10.12, Fedora Linux 23, Fedora Linux 24, openSUSE 42.3, Ubuntu Linux 16.04 LTS
- Software Included
- Drivers & Utilities
- First Copy Out Time B/W
- 9 sec
- First Copy Out Time Colour
- 9.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1400 pages , 1 x toner cartridge (cyan) - up to 1400 pages , 1 x toner cartridge (magenta) - up to 1400 pages , 1 x toner cartridge (yellow) - up to 1400 pages , 1 x developer , 1 x photoconductor unit
- FCC Class B certified, C-Tick, cUL, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, Directive 1275/2008/EC, ECMA-370, EFTA, TER, ISO 532B, CAN/CSA-C22.2 No. 60950-1
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 4 Years
- 44.2 cm
- 58.8 cm
- 46.2 cm
- 27.1 kg
- Shipping Width
- 55.8 cm
- Shipping Depth
- 59.4 cm
- Shipping Height
- 57 cm
- Shipping Weight
- 30.8 kg
- Sound Emission
- 52 dBA (operating)
- 10 °C
- 32 °C
- 8 - 80%
