Brand
Lexmark MB2546adwe Mono Laser Multifunction Printer
Quicklinx: F8GVWS00 Mfr#: 36SC551
£403.66 ex VAT
£484.39 inc VAT
Work fast and run economically with the MB2546adwe, the fax-equipped high speed multifunction product with long-life components and standard Wi-Fi.
  • 4-year guarantee upon registration
    For an added level of peace of mind, you can benefit from 4-year guarantee coverage upon registration.
  • Ready when you are
    Robust and reliable, Lexmark multifunction products are built to work anywhere, from showroom to warehouse, with few interventions. Keep going with long-life components, replacement cartridge yields of up to 10,000 pages and a maximum input capacity of 2,000 pages.
  • Full-spectrum security
    Lexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help to keep your information safe - in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honoured Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
  • Get more done
    When performance meets simplicity, you get more done. The intuitive 10 cm tablet-like colour touch screen makes your tasks easy, and it's the gateway to built-in productivity apps that save time and improve efficiency. With 44-pages-per-minute printing, and a skilled scanner that can accurately capture up to 42 images per minute, even with mixed originals, you'll get what you need in a flash.
  • Wireless convenience
    USB and gigabit ethernet connections are just the start. Standard Wi-Fi means convenient and secure connectivity, whilst the Lexmark Mobile Assistant app allows fast and easy setup directly from your mobile device.
  • Dual-core power
    A 1 GHz dual-core processor with 1 GB of standard memory gives you the power to do a combination of faxing, printing, copying and scanning for maximum productivity. And you can be confident that your complex file with images, charts and small print will look just as the way that you designed it.
  • Energy efficiency
    Make every watt count with energy management features that reduce power consumption, whether the printer is active or in sleep mode. Lower fusing temperature and automatic management of processor cores based on workload help to meet rigorous ENERGY STAR 2.0 requirements. That benefits the planet and your budget.
Lexmark MB2546adwe - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
120000 pages
Recommended Monthly Volume
2000 - 15000 pages
Max Copying Speed
Up to 44 ppm
Max Printing Speed
Up to 44 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Printing Resolution Class
Max Fax Transmission Speed
33.6 Kbps
Scanning
1200 x 600 dpi (600 x 600 dpi color)
Display
4.3"
Original Size
215.9 x 355.6 mm (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, card stock
Standard Media Capacity
350 sheets
Max Media Capacity
2000 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB 2.0 host
Office Machine Features
Scan to e-mail, scan to network, scan to FTP, scan to USB host, internal card slot
48.9 cm x 42.95 cm x 47.7 cm
20.6 kg
Environmental Standards
ENERGY STAR Qualified
4-year warranty with product registration
Printer Fonts
Bitmapped PCL x 2 , Scalable PCL x 84 , Scalable PostScript x 91 , Bitmapped PPDS x 5 , Scalable PPDS x 39
Fax Type
Plain paper
Printing Technology
Laser - monochrome
120000 pages
2000 - 15000 pages
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
Standard Memory
1 GB
Max Supported Memory
1 GB
Copying
Max Copying Speed
Up to 44 ppm
Max Document Enlargement
400%
Max Document Reduction
25%
Automatic Duplexing
Printing
Max Printing Speed
Up to 44 ppm
Printer Drivers / Emulations
PCL 5e, PCL 6, PostScript 3, PPDS, PDF 1.7, XPS
Image Enhancement Technology
1200 IQ, 2400 IQ
Automatic Duplexing
First Print Out Time B/W
6 sec
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
Document & Media Handling
Max Original Size
215.9 x 355.6 mm
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
Supported Envelope Sizes
US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
350 sheets
Max Media Capacity
2000 sheets
100 sheets
150 sheets
Multi-purpose tray - 100 sheets , Input tray - 250 sheets weight: 60 g/m² - 120 g/m² , RADF - 50 sheets , Output tray - 150 sheets
Speed Details
Printing: up to 44 ppm (A4) - B/W , Printing: up to 22 spm (A4) - B/W duplex , Copying: up to 44 ppm (A4) - B/W , Copying: up to 23 spm (A4) - B/W duplex , Scanning: up to 42 spm (A4) - B/W , Scanning: up to 45 spm (Letter A) - B/W , Scanning: up to 20 spm (A4) - colour , Scanning: up to 22 spm (Letter A) - colour , Scanning: up to 20 spm (A4/Letter A) - B/W duplex , Scanning: up to 10.5 spm (A4/Letter A) - colour duplex
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 2 x USB 2.0 host - 4 pin USB Type A
Security Protocols & Features
SSL, LEAP, TLS, IPsec, 802.1x, ARP, TTLS, PEAP, MD5, MS-CHAPv2, SNMP 3
Operating System Support
Novell NetWare 6, SuSE Linux Enterprise Server 10, SuSE Linux Enterprise Server 11, Novell NetWare 5.1, Novell NetWare 6.5, SunSoft Solaris x86 10, IBM AIX 6.1, Apple Mac OS X 10.6, Apple Mac OS X 10.7, Red Hat Enterprise Linux WS 6.0, IBM AIX 7.1, Apple Mac OS X 10.8, SunSoft Solaris x86 11, SunSoft Solaris SPARC Platform Edition 10, SunSoft Solaris SPARC Platform Edition 11, Apple Mac OS X 10.9, MS Windows 7 (32/64 bits), Debian Linux 7.0, Apple Mac OS X 10.10, Windows 8 (32/64-bits), Windows 8.1 (32/64-bits), Windows 10, Apple Mac OS X 10.11, openSUSE 13.2, Novell Open Enterprise Server 2, Debian Linux 8.0, SuSE Linux Enterprise Server 12, Novell Open Enterprise Server 11, Red Hat Enterprise Linux WS 7.0, macOS 10.12, Fedora Linux 23, Fedora Linux 24, macOS 10.13, openSUSE 42.3, Ubuntu Linux 16.04 LTS
Software Included
Drivers & Utilities
620 Watt
Power Consumption Standby
14.5 Watt
Power Consumption Sleep
2.6 Watt
First Copy Out Time B/W
6 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19752 , 1 x imaging unit - up to 60000 pages at 5% coverage
FCC Class B certified, C-Tick, cUL, GS, NOM, CB, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, ECMA-370, EFTA, TER, MET, ISO 532B, TED, CAN/CSA-C22.2 No. 60950-1
ENERGY STAR Certified
Limited warranty - 4 Years
48.9 cm
42.95 cm
47.7 cm
20.6 kg
Shipping Width
51.1 cm
Shipping Depth
57.6 cm
Shipping Height
61.4 cm
Shipping Weight
23.72 kg
Sound Emission
14 dBA (idle) / 56 dBA (operating)
10 °C
32 °C
8 - 80%
Functionality: Fax
Functionality: Scanner
Functionality: Copier
Functionality: Printer
Max Paper Size: A4 (210 x 297 mm)
Brand: Lexmark
