Strike the perfect balance of performance and affordability in small-workgroup mono printing with standard two-sided output, enhanced security and built-in durability. The Lexmark MS420 series' multi-core processor supports high output, while long-lasting printing components reduce downtime. Plus, you can connect via standard USB or Gigabit Ethernet.
                Ready when you areRobust and reliable, Lexmark printers are built to work anywhere, from showroom to warehouse with few interventions. Keep going with long-life components and replacement cartridge yields of up to 20,000 pages.
                Full-spectrum securityLexmark's comprehensive approach to product security is a design and engineering mandate across our entire product portfolio. Our security features help to keep your information safe - in the document, on the device, over the network and at all points in between. That's why Keypoint Intelligence - Buyers Lab honoured Lexmark with a prestigious BLI PaceSetter award for Document Imaging Security. And this Lexmark product enables you to be GDPR ready.
                Performance and valueGet mono printing at up to 40 pages per minute, plus standard two-sided printing, at an affordable price. Durability and long-life components keep your maintenance costs low, too.
                Energy efficiencyMake every watt count with energy management features that reduce power consumption, whether the printer is active or in sleep mode. Lower fusing temperature and automatic management of processor cores based on workload help to meet rigorous ENERGY STAR 2.0 requirements. That benefits the planet and your budget.
                The definition of clear textSome laser printers struggle to print grey text that's easy to read - not the MS420 series. Its innovative font outlining technology makes even the smallest grey text crisp and clear.
                Versatile media handlingPrint what you want, in the size that you want. The standard media tray adjusts to paper sizes from A6 to legal, whilst the 100-sheet multipurpose feeder accepts smaller media and envelopes to give you even more design and output possibilities.
- Lexmark MS421dn - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 14 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Print Speed
- Up to 40 ppm - B/W (ISO/IEC 24734) , Up to 20 spm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Max Resolution Class (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- 2400 IQ
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN
- AirPrint Enabled
- Processor
- 1 GHz
- RAM Installed (Max)
- 512 MB (512 MB)
- Language Simulation
- PCL 5E, PostScript 3, PCL 6, XPS, PDF 1.7
- Barcodes
- OCR-A, OCR-B
- Media Type
- Envelopes, transparencies, labels, plain paper, card stock
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet input tray
- Monthly Duty Cycle (max)
- 100000 pages
- Recommended Monthly Volume
- 1000 - 10000 pages
- Networking
- Print server
- System Requirements
- Microsoft Windows 7, SunSoft Solaris x86 10, SuSE Linux Enterprise Server 11, Apple MacOS X 10.6, Microsoft Windows 7 64-bit Edition, SuSE Linux Enterprise Server 10, Apple MacOS X 10.5, IBM AIX 6.1, Apple MacOS X Lion 10.7, Windows 8, IBM AIX 7.1, SunSoft Solaris x86 11, Red Hat Enterprise Linux WS 6, Apple OS X 10.8 Mountain Lion, Windows 8 64-bit Edition, Debian GNU/Linux 7.0, Windows 8.1 64-bit Edition, Windows 8.1, Apple OS X 10.9 Mavericks, Apple MacOS X 10.10, Windows 10, SuSE Linux Enterprise Server 12, Apple MacOS X 10.11, Debian GNU/Linux 8.0, Red Hat Enterprise Linux WS 7, Ubuntu 16.04 LTS, SUSE Linux 13.2, Apple macOS 10.12, Linux Fedora 23, Linux Fedora 24, openSUSE 42.3
- 1-year warranty
- 39.9 cm x 37.4 cm x 26 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- 2 line monochrome OLED display
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- 1200 x 1200 dpi
- 2400 IQ
- PostScript Support
- Standard
- First Print Out Time B/W
- 6.25 sec
- Fonts Included
- 91 x scalable PostScript , 2 x bitmapped PCL , 84 x scalable PCL , 39 x scalable PPDS , 5 x bitmapped PPDS
- Barcodes
- OCR-A, OCR-B
- Media Handling
- Processor
- 1 GHz
RAM
- 512 MB / 512 MB (max)
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), Monarch (98.4 x 190.5 mm), US No 9 (98.6 x 225.6 mm)
- Media Weight
- 60 g/m² - 216 g/m²
- 350 sheets
- Media Feeders
- Input tray: 1 - 250 sheets weight: 60 g/m² - 120 g/m² , Bypass tray: 1 - 100 sheets weight: 60 g/m² - 216 g/m²
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 100000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, TFTP, IPP 1.0, IPP 1.1, IPP 2.0
- SSL, LEAP, TLS, 802.1x, TTLS, PEAP, MD5, EAP-MSCHAPv2
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages ISO/IEC 19752 , 1 x imaging unit - up to 60000 pages at 5% coverage
- FCC Class B certified, UL, C-Tick, cUL, GS, NOM, ICES-003 Class B, CCC, DOC, SII, UL 60950-1, IEC 60950-1, EN 60950-1, BSMI Class B, KCC, IEC 60825-1, FDA, UL-AR, GOST-R, EN 60825-1, KC, CECP, CEL, VCCI Class B, ECMA-370, EFTA, TER, ISO 532B, TED, CAN/CSA-C22.2 No. 60950-1
- Power Device
- Power supply - internal
- 570 Watt
- Power Consumption Stand by
- 7.5 Watt
- Power Consumption Sleep
- 1.9 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- Limited warranty - 1 year - carry-in
- 16 °C
- 32 °C
- 8 - 80%
- Sound Emission (Idle)
- 14 dBA
- Sound Emission (Operating)
- 55 dBA
- 39.9 cm
- 37.4 cm
- 26 cm
- 14 kg
- Width (Shipping)
- 43 cm
- Depth (Shipping)
- 47 cm
- Height (Shipping)
- 37.6 cm
- Weight (Shipping)
- 15.81 kg
