Lexmark's CX727de is a very fast color MFP that prints up to 47 ppm and scans up to 56 sides or images per minute.
4 year guarantee? upon registration?
For an added level of peace of mind, you can benefit from 4-year guarantee coverage? upon registration?. -
Quad core power
A 1.2GHz quad core processor with up to 4GB of memory gives the CX727de fast and powerful print capabilities. -
Exceptional colour
Professional colour features including ultra-sharp 4800 Colour Quality, PANTONE calibration and Lexmark Colour Replacement work with Unison Toner to deliver precision matching for critical colours. -
Solutions flexibility
Lexmark's Embedded Solutions Framework applications let you run software solutions to meet the needs of your industry. -
Versatile media handling
Media loading and feeding are engineered for ease, reliability and versatility, with up to 650 pages of input capacity (expandable to 2,300), small-media and banner-length support, and exceptionally durable input trays that resist misfeeds. -
Light touchscreen
A bright, 17.8 cm e-Task colour touch screen features an ultra-smooth surface and can be activated by almost anything, including pens, fingertips or nails-without pressure or direct skin contact. -
Advanced scanning
Automatic de-skew, mixed-size scanning, page-level jam recovery and integrated file compression make the CX727de a scanning workhorse.
- Lexmark CX727de - multifunction printer - colour
- Multifunction printer
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 150000 pages
- Recommended Monthly Volume
- 2000 - 20000 pages
- Max Copying Speed
- Up to 47 ppm (mono) / up to 47 ppm (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 600 dpi (300 x 300 dpi colour)
- Display
- 7"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, card stock
- Standard Media Capacity
- 650 sheets
- Max Media Capacity
- 2300 sheets
- Bypass Feeder Capacity
- 100 sheets
- Output Trays Capacity
- 300 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing) Yes (scanning)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, USB 2.0 host
- AirPrint Enabled
- Office Machine Features
- Scan to e-mail, scan to network, scan to FTP
- 50.55 cm x 53.3 cm x 64.8 cm
- 44.9 kg
- Environmental Standards
- ENERGY STAR Qualified
- 4 years warranty
- Fax Type
- Plain paper
- Laser - colour
- 150000 pages
- Display Diagonal Size
- 7"
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 2 GB
- Max Supported Memory
- 4 GB
Copying
- Max Copying Speed
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3, PCL 5c, PPDS, PDF 1.7, XPS
- Image Enhancement Technology
- 4800CQ
- First Print Out Time B/W
- 5 sec
- First Print Out Time Colour
- 5.5 sec
Scanning
- Scan Element
- CCD
- Optical Resolution
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
Fax Machine Features
- Colour faxing
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 218 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm)
- Supported Envelope Sizes
- US No 10 (104.7 x 241.3 mm), International DL (110 x 220 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), US No 9 (98.6 x 225.6 mm)
- 650 sheets
- 2300 sheets
- 100 sheets
- 300 sheets
- Input tray - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 218 g/m² , Input tray - 550 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 218 g/m² , ADF - 50 sheets , Output tray - 300 sheets
- Speed Details
- Printing: up to 47 ppm (A4) - B/W , Printing: up to 47 ppm (A4) - colour , Printing: up to 38 spm (A4) - B/W duplex , Copying: up to 47 ppm (A4) - B/W , Copying: up to 47 ppm (A4) - colour , Scanning: up to 56 spm (A4) - B/W , Scanning: up to 56 spm (A4) - colour , Scanning: up to 26 spm (A4) - B/W duplex , Scanning: up to 28 spm (Letter A) - B/W duplex , Scanning: up to 26 spm (A4) - colour duplex , Scanning: up to 28 spm (Letter A) - colour duplex , Scanning: up to 60 spm (Letter A) - B/W , Scanning: up to 60 spm (Letter A) - colour
- 1 x USB 2.0 - 4 pin USB Type B , 2 x USB 2.0 host - 4 pin USB Type A , 1 x Gigabit LAN - RJ-45
- SSL, Apple Bonjour, TLS, ARP
- Operating System Support
- MS Windows XP, MS Windows Server 2008 x64 Edition, MS Windows 7, MS Windows 7 64-bit Edition, MS Windows Vista, MS Windows XP 64-bit Edition, MS Windows Vista (64-bit versions), Sun Solaris 10, MS Windows Server 2008, Novell NetWare 6.5, IBM AIX 6.1, MS Windows Server 2008 R2, IBM AIX 7.1, MS Windows Server 2012, Windows 8, Windows RT, Windows 8 64-bit, Windows 8.1, Windows 8.1 64-bit, MS Windows Server 2012 R2, Windows RT 8.1, Sun Solaris 11, Windows 10, Novell Open Enterprise Server 2, Novell Open Enterprise Server 11
- 700 Watt
- Power Consumption Standby
- 100 Watt
- Power Consumption Sleep
- 2.6 Watt
- First Copy Out Time B/W
- 6.5 sec
- First Copy Out Time Colour
- 7 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 7000 pages , 1 x toner cartridge (cyan) - up to 3000 pages , 1 x toner cartridge (magenta) - up to 3000 pages , 1 x toner cartridge (yellow) - up to 3000 pages
- FCC Class B certified, CSA, UL, VCCI Class B ITE, CISPR 22 Class B, DEMKO, GS, EN55024, IEC 60320-1, EN55022 Class B, CB, ICES-003 Class B, C-Tick Class B, MIC, EK, UL 60950-1, IEC 60950-1, EN 60950-1, CCC Class B, BSMI Class B, IEC 60825-1, FDA, CAN/CSA-C22.2 No. 60950-1
- ENERGY STAR Certified
- Limited warranty - 4 Years
- 50.55 cm
- 53.3 cm
- 64.8 cm
- 44.9 kg
- Shipping Width
- 70 cm
- Shipping Depth
- 73.5 cm
- Shipping Height
- 95.5 cm
- Shipping Weight
- 64 kg
- Sound Emission
- 53 dBA (operating)
- 10 °C
- 32 °C
- 8 - 80%
Lexmark Cs/Cx727/Cs728 Cyan Return Program Toner Cartridge 10K | In Stock | £217.58 |
Lexmark Cs/Cx727/Cs728 Bk Return Program Toner Cartridge 13K | In Stock | £162.97 |
Lexmark Cs/Cx727/Cs728 Mage Return Program Toner Cartridge 10K | In Stock | £217.58 |
Lexmark Cs/Cx727/Cs728 Yell Return Program Toner Cart 10K | In Stock | £217.58 |
Lexmark CS720/725/CX725 Black Return Programme Imaging Kit | In Stock | £68.17 |
Lexmark Waste Toner Bottle | In Stock | £23.93 |
