The readers, storage drives, and hubs leverage USB 3.0 technology for high-speed performance, while the Professional Workflow HR2 hub and CR2 CFast 2.0 reader are also designed to deliver next-generation Thunderbolt 2 speeds. Thunderbolt 2 technology gives photographers and videographers the power to quickly transfer 4K video and other large media files, at up to twice the speed of Thunderbolt and up to 4x the speed of USB 3.0 devices.
Offload your work, faster
The readers, storage drives, and hubs leverage USB 3.0 technology for high-speed performance, while the Professional Workflow HR2 hub and CR2 CFast 2.0 reader are also designed to deliver next-generation Thunderbolt 2 speeds. Thunderbolt 2 technology gives photographers and videographers the power to quickly transfer 4K video and other large media files, at up to twice the speed of Thunderbolt and up to 4x the speed of USB 3.0 devices. -
Simple setup and use
Simply plug the readers or storage drives of choice into the hub and start transferring and archiving files. It's that easy. Also, the Professional Workflow HR2 hub provides two Thunderbolt 2 ports and one USB 3.0 port, making it easy to daisy-chain with your existing setup. Having two Thunderbolt 2 ports also allows you to place the hub anywhere in your lineup of other Thunderbolt devices to create a unique, customizable setup. The hubs help you eliminate cable clutter and take control of your workflow. -
Future-proof your workflow setup
The modular design of the Professional Workflow line of products makes it adaptable to changing technology. As Lexar features card formats and additional storage drives for this system, you'll be able to swap in products to meet your growing and changing needs.
- Lexar Professional Workflow DD256 - SSD - 256 GB - USB 3.0
- Solid state drive - external (portable)
- Capacity
- 256 GB
- Interface
- USB 3.0
- Built-in capacity meter
- 2-year warranty
- Capacity
- 256 GB
- Interface
- USB 3.0
Expansion & Connectivity
- 1 x USB 3.0
- Cables Included
- 1 x USB 3.0 cable
- Limited warranty - 2 years
