Lenovo ThinkVision L24e-20 23.8" 1920x1080 4ms VGA HDMI LED Monitor
Quicklinx: FHP6WS00 Mfr#: 65DFKAC1UK
Designed keeping style and functionality in mind, this sleek Lenovo L24e-20 monitor is all set to give you an incredible viewing experience. With the 23.8" NearEdgeless design and a 178°/178° wide viewing angle, the Lenovo L24e-20 monitor enables you to enjoy content consumption activities on a magnificent canvas. The TÜV Low Blue Light certification and flicker-free display reduces eye strain and makes long viewing hours comfortable. Also, you can adjust the monitor the way you want with the Quick Release Tilt Stand or mount it on a wall with VESA compatible slots to make extra desk-space. Plug in your gaming console, media player, or any other streaming device simultaneously with the multiple connectivity options.
Lenovo l24e-20 - LED monitor - Full HD (1080p) - 23.8"
LED-backlit LCD monitor - 23.8"
Energy Class
Class E
Power Consumption (On mode)
15.2 W
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 75 Hz
Input Connectors
HDMI, VGA
Display Position Adjustments
Tilt
Voltage
53.95 cm x 19 cm x 40.27 cm
English / United Kingdom
Environmental Standards
ENERGY STAR Qualified
DDC/CI, RoHS, WEEE, TUV Rheinland Low Blue Light Certification, VESA TMDS
Display Type
Energy Class
Class E
Diagonal Size
23.8"
Aspect Ratio
16:9
Native Resolution
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
54 - 90 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Backlight Technology
WLED
Flicker Free technology
HDMI , VGA (HD-15) , Headphones
Mechanical
Tilt
Tilt Angle
-5/+22
VESA Mounting Interface
100 x 100 mm
1 x VGA cable - 1.8 m
Input Voltage
15.2 W
15.2 kWh/1000h
Power Consumption (Typical)
24 Watt
Power Consumption Stand by
0.3 Watt
Power Consumption (Off Mode)
0.3 Watt
Sustainability Information
ENERGY STAR Certified
45 °C
10 - 80% (non-condensing)
