- Lenovo ThinkVision M14 - LED monitor - Full HD (1080p) - 14"
- LED-backlit LCD monitor - 14"
- Energy Consumption per Year
- 15.53 kWh
- Power Consumption (On mode)
- 4.88 W
- USB PD 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Full HD (1080p) 1920 x 1080 at 60 Hz
- Pixel Pitch
- 0.1611 mm
- Brightness
- 300 cd/m²
- Contrast Ratio
- 700:1 / 3000000:1 (dynamic)
- Response Time
- 6 ms
- Colour Support
- 16.7 million colours
- Input Connectors
- 2xUSB-C
- Height, tilt
- Screen Coating
- Anti-glare
- Raven black
- 32.337 cm x 9.654 cm x 20.903 cm
- 0.57 kg
- Localisation
- English / United Kingdom
- Environmental Standards
- ENERGY STAR Qualified
- CCC, RoHS, ISO 9241-307, Directive 2002/95/EC, China Energy standard Tier 2
- 3-year warranty
- Display Type
- 15.53 kWh
- Diagonal Size
- 14"
- Viewable Size
- 14"
- USB Power Delivery
- 65 Watt
- Panel Type
- IPS
- Aspect Ratio
- 16:9
- Native Resolution
- Pixel Pitch
- 0.1611 mm
- Pixel Per Inch
- 157
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- 6 ms
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- WLED
- Bezel Type
- Raised
- 72% NTSC (CIE 1931) colour gamut, Low Blue Light Mode, Mercury free, arsenic-free glass, Eye comfort mode, Eye-Care Technology, 8-bit + A-FRC Colour Depth
- Raven black
- 32.337 cm x 9.654 cm x 20.903 cm - with stand
- 0.57 kg
- 2 x USB-C 3.1 Gen 1/DisplayPort with Power Delivery 2.0 (power up to 65W)
Mechanical
- Height, tilt
- Tilt Angle
- -5/+90
- VESA Mounting Interface
- 100 x 100 mm
- Included Accessories
- Clips
- Cables Included
- 1 x USB-C cable - 1 m
- Localisation
- Security Slot Type
- Kensington security slot
- Voltage Required
- AC 120/230 V (50/60 Hz)
- 4.88 W
- 6 Watt
- Power Consumption (Typical)
- 6 Watt
- Power Consumption Stand by
- 0.3 Watt
- Power Consumption Sleep
- 0.3 Watt
- 0.3 Watt
- On / Off Switch
- OS Required
- Microsoft Windows 7 / 8 / 8.1 / 10
- Dimensions & Weight Details
- With stand (highest position) - width: 32.337 cm - depth: 9.654 cm - height: 22.003 cm - weight: 570 g , With stand (lowest position) - width: 32.337 cm - depth: 9.654 cm - height: 20.903 cm - weight: 570 g
- Shipping Width
- 40.2 cm
- Shipping Depth
- 27.6 cm
- Shipping Height
- 6.1 cm
- Shipping Weight
- 1.67 kg
- ENERGY STAR Certified
- ENERGY STAR Version
- 7.1
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 30 - 80%
