LaCie 250GB Rugged SSD Thunderbolt 64MB 2.5" Portable Hard Drive
Quicklinx: 9LW5WS00 Mfr#: LAC9000490
Deadlines rule our world. When digital storage is critical for your project, it had better be as fast and reliable as you are. From the desktop to the badlands, it has to connect to any computer, deliver more than enough speed for the most demanding applications, and protect data against any threat.
  • Universal connectivity
    Don't let your project get derailed by external drive/computer incompatibility. With both USB 3.0 and Thunderbolt interfaces, the LaCie Rugged is a perfect match for your Mac and PC. And because USB 3.0 is backwards compatible, you can connect it to any standard computer on the planet. The LaCie Rugged is also fully bus-powered through the included USB 3.0 and Thunderbolt cables. Its portability and interfaces make it the must-have sidekick to a new Mac or Ultrabook.
  • No-compromise speed
    Get lightning-fast transfer speeds on Mac and PC thanks to the USB 3.0 and Thunderbolt interfaces. Back up and transfer mountains of data in a fraction of the time. Enjoy noticeably more responsive photo library browsing.
LaCie Rugged Thunderbolt - SSD - 250 GB - USB 3.0 / Thunderbolt
Solid state drive - external (portable)
250 GB
Data Transfer Rate
10 Gbps (Thunderbolt) / 5.0 Gbps (USB 3.0)
Shock resistant, water resistant, rugged pocket-sized design, password authentication, dust-proof, automatic backup, software encryption, 256-bit AES
Power Source
USB bus, Thunderbolt bus
89 mm x 140 mm x 24 mm
280 g
3-year warranty
250 GB
Internal Drive Interface
SATA 6 Gb/s
89 mm
140 mm
24 mm
280 g
Performance
Interface Transfer Rate
Max Data Transfer Rate
387 MB/s
Expansion & Connectivity
1 x USB 3.0
Power Source
Software Included
LaCie Backup Assistant, LaCie Private-Public
Apple MacOS X 10.6 or later, Microsoft Windows Vista / XP / 7 / 8
Protective cover
1 x Thunderbolt cable - integrated , 1 x USB 3.0 cable - external
IP54
Limited warranty - 3 years
