Kyocera FS-C8025MFP A3 Colour Laser Multifunction Printer
Quicklinx: C5Y7WS00 Mfr#: 1102MY3NL0
The ECOSYS FS-C8525MFP A3 multifunction color printer offers all the benefits of a professional document management solution for workgroups and small offices. Featuring Hybrid platform for advanced solutions, easy-to-operate touch screen and a range of paper-handling options, all in a well-designed compact package. Cost-efficient and eco-friendly offices will appreciate Kyocera's unique ECOSYS technology which increases operating life, reduces environmental impact, cuts printing costs and ensures reliability.
  • Efficient connectivity
    With both Gigabit Ethernet and USB 2.0 interfaces, this device ensures seamless integration into any office network, facilitating quick and easy setup.
  • Advanced copying capabilities
    Boasts automatic duplexing and a variety of copying features including 2 on 1 and 4 on 1, allowing for efficient document management and reproduction at resolutions up to 600 x 600 DPI for both black and white and color copies.
  • Comprehensive media handling
    Supports a wide range of media sizes and types, from A3 and Ledger to envelopes and plain paper, coupled with a maximum media capacity of 1600 sheets, making it ideal for businesses with diverse printing needs.
  • High-quality printing and scanning
    Features a laser printing technology that delivers high-resolution output at 600 x 600 DPI for both black and white and color documents, alongside automatic duplexing and fast first print out times.
  • Eco-friendly and compliant
    Adheres to ISO 14001 and ISO 9001 standards, ensuring environmentally friendly operation and quality management systems for peace of mind.
Kyocera FS-C8525MFP - multifunction printer - colour
Multifunction printer
Copier Type
Digital
Printing Technology
Laser (colour)
Max Copying Speed
Up to 25 ppm (mono) / up to 25 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Scanning
600 x 600 dpi
Original Size
98 x 148 mm (min) - A3/Ledger (297 x 432 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
140 x 182 mm (min) - A3 (297 x 420 mm), ANSI B (Ledger) (279 x 432 mm) (max)
Media Type
Envelopes, plain paper
Standard Media Capacity
600 sheets
Max Media Capacity
1600 sheets
Bypass Feeder Capacity
100 sheets
Output Trays Capacity
280 sheets
Automatic Duplexing
Yes (copying) Yes (printing) Yes (scanning)
Connection Availability
USB 2.0, Gigabit LAN, USB host
Office Machine Features
Save to USB flash drive, scan to e-mail, scan to folder, scan to network, HyPAS (Hybrid Platform for Advanced Solutions)
AC 230 V (50/60Hz)
59 cm x 59 cm x 74.8 cm
80 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Printing Technology
Laser - colour
Display Features
Touch screen
Standard Memory
1.5 GB 1.5 GB
Max Supported Memory
2 GB 2 GB
Copying
Max Copying Speed
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Printer Drivers / Emulations
PCL 6, PCL 5c, KPDL3, PCL 6 (XL), PDF, XPS
Automatic Duplexing
First Print Out Time B/W
10 sec
First Print Out Time Colour
12 sec
Scanning
Automatic Duplexing
Optical Resolution
600 x 600 dpi
Grayscale Depth
8-bit
Document & Media Handling
Min Original Size
98 x 148 mm
Max Original Size
Original Type
Sheets
50 sheets
Min Media Size
140 x 182 mm
Max Media Size
A3/Ledger
Min Media Weight
60 g/m²
Max Media Weight
256 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), A6 (105 x 148 mm), ANSI B (Ledger) (279 x 432 mm), Folio (216 x 330 mm)
600 sheets
Max Media Capacity
1600 sheets
100 sheets
280 sheets
Paper cassette - 500 sheets - A3 (297 x 420 mm) weight: 60 g/m² - 256 g/m² , Bypass tray - 100 sheets size: 98 x 148 mm - A3/Ledger (297 x 432 mm) weight: 60 g/m² - 256 g/m² , ADF - 50 sheets size: 140 x 182 mm - A3/Ledger (297 x 432 mm) weight: 45 g/m² - 160 g/m² , Output tray - 250 sheets , Job separator tray - 30 sheets
Speed Details
Printing: up to 25 ppm (A4) - B/W , Printing: up to 25 ppm (A4) - colour , Copying: up to 25 ppm (A4) - B/W , Copying: up to 25 ppm (A4) - colour , Printing: up to 13 ppm (A3) - B/W , Printing: up to 13 ppm (A3) - colour , Copying: up to 13 ppm (A3) - B/W , Copying: up to 13 ppm (A3) - colour , Scanning: up to 40 ipm (A4) - B/W , Scanning: up to 40 ipm (A4) - colour
1 x USB 2.0 , 1 x USB host , 1 x Gigabit LAN
Operating System Support
UNIX, Linux, Apple MacOS X 10.4 or later, MS Windows
AC 230 V (50/60Hz)
597 Watt
Power Consumption Standby
125 Watt
Power Consumption Sleep
0.9 Watt
Warm-Up Time
45 sec
First Copy Out Time B/W
11.7 sec
First Copy Out Time Colour
13.6 sec
Consumables Included
1 x toner cartridge (black) - up to 3000 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
TUV GS, ISO 9001, ISO 14001
ENERGY STAR Certified
59 cm
59 cm
74.8 cm
80 kg
Sound Emission
35 dBA (idle) / 49 dBA (operating)
